Question about Coleman Heating & Cooling
I have a 1993 yellowstone camper with a coleman wall thermostat. on the bottom of it- it has a heat/cool switch on one side and the other side has a low-high-fan switch. when we run it on low or high it gets cool but the fan never shuts off.if we put it on fan it shuts off with the compressor but it doesn't blow cool air. any advise?
Thank you so very much for your answer! I'm glad I came to this website before I began a new project. I was about to re-wire my unit based on my ex-husbands advice!!!!
Posted on Jun 13, 2013
  • 828 Answers
These unit are set up for continuous fan operation when turned on. It does not have an automatic position on your thermostat such as in your house. Set the fan speed to what you are comfortable with and let the thermostat control the temperature.
Posted on Jul 21, 2008
Coleman mach thermostat constantly clicking when i put it to heat mode for my suburban gas heater in my camper have replaced circuit board, thermostat, and cleaned it
sounds like backfeeding voltage to the stat. with a meter and the wires off the stat be sure you only have voltage to your red. possibly have a pinched wire somewhere.
Oct 21, 2017 | Coleman Heating & Cooling
Why is campers inn saying I need to replace my Coleman Mach 3 with a Coleman Mach 8?
we would have no idea . perhaps if you contact Coleman they can tell you .
Feb 15, 2017 | Coleman Heating & Cooling
I have a coleman Evcon model AH16-0 . I am
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Jan 06, 2010 | Heating & Cooling
COLEMAN MACH 3 MOUNTING ON INSIDE OF CAMPER NOT ALIGNING WITH MY
Did you purchase a new Ducted Ceiling Unit with the Upper Unit air conditioner? If you are replacing an older mach 3, the ducted ceiling packs are not compatible and you will need to purchase the ceiling pack as well. The ducted ceiling pack part number for the 8333 series Mach III AC is below.
1. Heat/Cool Air Distribution Box - 8330B735
2. Cool only ADB - 8330A733
3. Wall Thermostat (if needed) - 7330G3351
Hope this helps.
Jul 01, 2009 | Coleman Heating & Cooling
I have a 13,500 btu coleman on our 1989 avion camper. It was making a very loud noise for some time, and vibrating then the motor locked up on it. My husband thinks the blower went out on it. It was...
You should be able to turn the fan motor freely by hand. If there is any resistance or the noise turning it by hand, then the fan motor is definitely bad. Is it a wall thermostat unit or manual controls? Wall thermostat, you can use a jumper wire from the 12+ terminal of the thermostat to the HG terminal and the fan should come on, if not, then the motor is bad.
Jun 24, 2009 | Coleman Mach III Air Conditioner
Heating & Cooling Logo
79 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
