Question about HP VGA Webcam
Webcam won't work
Just bought an HP elite webcam and can't get it to work. The blue light goes off but can't get an image
    President:
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 13, 2009
My webcam is coming up very blue and fuzzy is there a way to fix that for the Toshiba satellite L655
Hello!
Webcams in general have very low resolution. But you can improve the appearance of your image with this little trick:
Before the webcam starts capturing, try pointing it to a light source, so when it starts it should receive enough light to provide a brighter image afterwards. You can take it off the light source when you see that the image improves and use it normally.
This happens because most webcams' drivers are programmed to display an image based on the initial light conditions. So if you start using it in a dark place, when you try to move to a brighter area, the image would look blue and fuzzy, as the webcam was adapted to those lightning conditions.
Hope this helps.
Good Luck!
May 04, 2011 | Computers & Internet
Tip
Solution to the HP Purple Web Cam Issue
This document is located on HP's web site concerning purple tint on certain web-cams.
This document pertains to certain HP Notebook PCs with Windows 7.
When using an HP ENVY 15 notebook PC webcam in low light conditions, images on the webcam may have a purple tint.The ENVY 15 Series webcams include night vision technology that is designed to operate in normal lighting conditions and optimized to operate in low and zero light conditions.The webcam night vision feature includes two Infrared (IR) lights located on each side of the webcam and behind the display panel bezel.
Low to zero light conditions will cause the webcam IR lights to activate. The IR lights provide illumination for low and zero light conditions and help prevent fuzzy images that are typically associated with operating standard webcams in low and zero light conditions.
Turn off the webcam IR lights. While some degree of purple tint may be present under low light conditions, turning off the webcam IR lights will reduce and in certain cases eliminate the purple tint.
  1. Select Start > All Programs > HP > HP MediaSmart > HP MediaSmart Webcam .
  2. In HP MediaSmart Webcam, select Settings > Display > Advanced Settings , and then click the Camera Control tab.
  3. Select the Low Light Compensation check box, and then click Apply .
  4. Click OK .
NOTE:Disabling the webcam IR lights will cause display images to appear darker in low and zero light conditions.
The webcam IR lights are also available on other webcam programs.
Refer to the software Help for additional information.
This document will be updated if additional information becomes available.
on Jul 28, 2010 | Computers & Internet
My HP Elite Autofus webcam works fine when recording/playing back to my laptop, but the audio does not reach Skype
Open Skype, click "Call" and select "Audio Settings..."
Click on the pull down menu next to Microphone and Speakers to make sure Skype is setup correctly.
Apr 14, 2011 | HP Elite Autofocus Webcam
Even though the camera works, the blue light no
Perhaps the LED burnt out or is defective, or a wired came loose inside the webcam. It might not matter as long as your webcam works. Test it on the free webcam test tool just to be sure.
May 11, 2010 | HP KQ246AA Deluxe Webcam
I have a hp g71 i would like to know how the
test your webcam by going to this website:
http://www.testmycam.net/
Mar 02, 2010 | HP Pavilion dv6000z Notebook
I have a problem with my webcam sound. I recorded my assignment speech and when i try to listen to the speech, there was no sound coming out from the webcam. i tried everything and nothing worked. Can you...
Hi chinonsobeau,
First off, you to list the model number of your HP web Cam, as well as your OS, and the software you using to record your sound. I will assume that you have Quickplay which HP ususally send out with their web cams.
To access QuickPlay, just press the "blue QuickPlay button" next to the power button. If it doesn't load QuickPlay, just do "Start" - "All Programs" - then you will see QuickPlay listed there. If you still can't find it just do a search, you will find the short-cut. If you still don't find it, then HERE is a place you can download it and use it. It also has instruction on how to use it.
Or sometimes HP sends out Cheese, another camera software. You can download that HERE.
These are the instructions for QuickPlay:
Once launched QuickPlay, click on the 2nd icon from left (between DVD and TV icon), then double-click on "HP Pavilion WebCam" from the left side panel, then you will see the blue LED light lit and you should see yourself on the screen. (Double-click "yourself" to enlarge image)
To take a picture or record video, just press the corresponding buttons on the top. (the red circle icon is for recording video (press "Stop" icon to stop recording), the camera icon is for, well, camera)
Videos and pictures are saved at:
Pictures -- C:\Users\Public\Pictures\My Snapshots
Videos -- C:\Users\Public\Videos\HP Webcam
I'm less familiar with Cheese, so I'll give you their website HERE to go to their support and they can guide you through their program.
Anyway, I hope this helps,
Don't forget to leave a raing,
Thanks
Mark
Videos -- C:\Users\Public\Videos\HP Webcam user_offline.gif
Oct 11, 2009 | HP Computers & Internet
How do i turn on my webcam
Yes, you can use the WebCam through QuickPlay, and yes, it works under Vista.
Have Fun! __________________
HP Pavilion dv6000t CTO
Microsoft Windows Vista Home Premium Build 6000
Core 2 Duo T5600 1.83 Ghz / 2MB L2 Cache
Jul 12, 2008 | HP Computers & Internet
Hp webcam in built
Hello
webcam has small CCD in it and if it goes bad it will show you blue or white image sometime and then other times it will work fine is it is showing you blue or white images sometimes you can take LCD bezel of and then replace webcam easily it is just a small board with CCD inbuilt.
Thankyou
May 05, 2008 | HP Pavilion dv9000z Notebook
HP VGA Webcam Logo
22 people viewed this question
Top HP Computers & Internet Experts
Tony
mukhtar21 shaikh
mukhtar21 shaikh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
