Question about Mitsubishi VS-45607 45" Rear Projection Television
Intermittent vertical jitter on Mistubishi tv 65000
  • 927 Answers
Good Day, sdkhanmd; Replace C2P05 100 UFD 16 VOLT off pin 3 IC2P01 and IC2P01 part #270P466020 (9 volt regulator). Both are on the signal PCB. Also, check other caps in area for leakage. Hope this was helpful, this common for this model. Good Luck, big IRISH.
Posted on Jul 31, 2008
I have a mistubishi tv model wd-65737 with bad picture. I replaced the video chip and color wheel but that didn't work....is it possibly that dmd board?..thx
Hi, can you tell me what you see on the screen? It could be a bad cable. Are you using an HDMI cable or the color cables (RCA cables)?
Jul 28, 2016 | Mitsubishi WD65737 65" DLP TV
I have a 65" Mistubishi WD - 65734 and have no
Yes,"LAMP" LED light indication front of tv bazel frame is on or blinking,yes mean tv projection lamp life are over.The whole tv warrenty only for a year,tv projection lamp should last at leat 1 1/2 or 2 years,by tv been on and watches used it like 4 or 5 hours daily?U never done tv replacement parts,any kinds before?Yes,hire a tv Tech. to do it.Shop around for a Tv tech.should replaced the projection lamp for u shoud be around $250 to $300 that including part the projection lamp.
Jan 03, 2011 | Mitsubishi WD-65734 65" HDTV
I have MISTUBISHI Montero car of 2008 model. I met with an major accident but yet my airbag didn't got open & that too while i was wearing sit belt. I need do have a complaint of this in Consumer Court...
Research DOT archives for similar investigative accident findings.
If your vehicle is REGULARLY maintained at a Manufacturer Dealership, you may have redress against them. All Diagnostic tests for Equipment Function, including the status of the AIR bag deployment system should be on the Vehicle History file, held on the Manufacturer Computer Mainframe, as and when, downloaded by the Servicing Dealer.
Regards, David
Nov 29, 2010 | Mitsubishi Montero Cars & Trucks
Mistubishi vs-6041 sound but no picture. Is it
it sounds like your speakers might be fried or just the wire loose or fried.
Sep 27, 2009 | Mitsubishi VS-6041 60" Rear Projection...
2000 mistubishi galant es idling rough seriously
Idling problems may be cause buy a number of issues.  You may check out the fast idle control valve and PCV if they would need cleaning.  You can check out the timing it may be advanced, that is why you feel that the car runs hard.
Jun 13, 2009 | 2000 Mitsubishi Galant
Mistubishi tv vertical hold not working
you can go to this link and one of thier tecs can help you out just leave them an e-mail with your model number and they kow how to do the bypass
Apr 10, 2008 | RCA D52W19 52" Rear Projection Television
Intermittent vertical jitter.
These sets have a PIP module which is plugged into main board and has a brown ground wire to the can.Surface mount caps c7001 and c7036 are usually the problem but if the capacitors have leaked too much you may never recover the board,CURE eliminate PIP by putting 10 mfd 50v cap from pin 5 to 11 and another from pin 9 to 7 on the VP plug under the main PCB
Nov 08, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-45607 45" Rear Projection Television Logo
100 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
