Question about Kenmore 43142 Front Load Washer
Kenmore Front Load Washer on the blitz
The lights on the control panel were blinking when I went to check the slip covers I was washing. In particular, the "add garment", "rinse", and "clothes clean" were all blinking on the status indicator and the door was locked. I finally managed to get the door to unlock but when I tried to restart the machine, nothing happened although I could hear a motor (or something) running. After about 3 minutes, it stopped and the blinking lights appeared. I unplugged and replugged it...waited 30 minutes and tried again with no results. No water, no movement, nada. I've called for service but am looking at Aug. 6 before someone can come to deal with it. Anything I can do in the meantime?
    Genius:
  • 1,028 Answers
Remove bottom panel and ck pump for obstruction especially if water is still in tub
Posted on Jul 22, 2008
Kenmore HE2 Won't Turn On
1) test the power cord for open 2) test the outlet box, see for blown fuse or c.breaker put some desk lamp and see if work 3) test inside of the control board if there fuse blown or c.breaker tripped 4( test the lid switch is closed, can be faulty or open replace 5) test the input voltage 115 if there are the control board faulty.
Jul 18, 2012 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite HE3 will not spin, sounds like slight gear slipping
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer wont start
open the back on the right side on the bottom panel,you well see lots of wires,NOW START tagging wires uses two people for this.it may be easy to change switch out
Jul 04, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore elite 3t the front light to select wash blinks but when s
Press 'drain' & 'spin' together for 3 seconds to see if it clears. This is your control panel lock.
If not cleared unplug the washer & wait for 30 minutes for the CCU (computer) to reset.
If helped you can rate.
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 front load washer the control lock is on and I don't
Look close at the panel.... it will tell you what button to hold in for 3-5 seconds
Good Luck!
Feb 24, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite won't start
First of all, make sure haven't inadvertently locked your control panel. Press and hold the DRAIN/SPIN button for 3 seconds to see if it clears. How long did you unplug the washer for? The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. Try this first and let me know what you have. It could be you only have a minor glitch.
If these preliminary checks prove unsuccessful, you may have a control panel problem. Do you have any error codes deisplayed? Please reply and let me know what you have.
Aug 25, 2008 | Kenmore Elite 45986 Front Load Washer
KENMORE ELITE PROBLEM
Press and hold the control lock button down until the light goes off. This is a child proof feature that may have come on if you leaned against it to long. After lock light goes off you can use the machine.
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 46462 powers off during spin cycle - no lights
i cleaned out the pump under the front bottom panel
Feb 03, 2008 | Kenmore 46462 Front Load Washer
Kenmore 43142 Front Load Washer Logo
109 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
