Question about Indesit W 123 Front Load Washer
Wd12 washer dryer(indesit)
How do i remove the bearing on the drum please?
  • 97 Answers
firstly the rubber seal needs to come out, then i usually use an old socket and long extension bar and knock them out with a large hammer. fitting is the opposite of removal. a word of caution though if the centre of the bearing is hit it can damage them. you may be best searching the site for an engineer in your area as it could turn costly if you get it wrong.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Posted on Jul 31, 2008
Make a lot of nosie
Hi mervyn2011
Sounds like you have a bearing problem or drum roller/slide problems.
You will need to take the dryer apart to determine which problem it is.
For an owners manual go to the following webpage
Please take time to rate me
For parts go to the following webpage.
Oct 16, 2012 | Indesit IS70C Electric Dryer
that dryer is obviously a vented dryer. the problem you are having is that the drum itself is falling back off the front bearing plate(i have actualy got a call in the morning for the same fault) the solution is to remove the back panel from the machine and place a washer about 4mm thick between the drum and rear panel on the shaft. this will solve your problem.
Feb 03, 2010 | Hotpoint Dryers
Indesit washer dryer starts cycle, waters then
If the heater element is not working, then the cycle will not progress.
You need to test the element to see if it is o/k.
Hope this helps.
Jan 05, 2010 | Indesit Washing Machines
Indesit WD12 door will not open once cycle has finsihed
I have the same problem and am now hoping you already have the solution ?!
Oct 09, 2009 | Washing Machines
Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
Mar 07, 2009 | Indesit W 123 Front Load Washer
Indesit WD12 washer dryer with a leaking door seal
this is no easy job and you will need a copy of the work-shop manual; sometimes they can be downloaded of the internet. There are no real specialist tools, but im telling you now there will be a lot of very red knuckles .good luck.adrian
Feb 22, 2009 | Indesit W 123 Front Load Washer
Door will not open on my washer dryer wd12 model
Unplug machine take lid off and release the door interlock with fingers from inside by forcing catch open,you need new interlock can be supplied.
Oct 07, 2008 | Indesit W 123 Front Load Washer
Indesit wd 12 drum
please rephrase your question as what you are explaining does'nt make sense
Feb 14, 2008 | Indesit W 123 Front Load Washer
WD12 Indesit washer/dryer
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: Timer- If your washing machine fills with water and begins agitating, but the timer won't advance. Then you need to replace the timer. Water supply problem- If water doesn't enter the machine when you start the process- check water entrance pipe, myaybe it was bend (if you have there a tap - see it is open). Check that water entrance valve works (it is an electromagnet valve,loocated at the pipe's enterance to the machine). If it doesn't work, test that it get power. In case it doesn't get power, it seems that the problem is with the timer unit. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve.
Mar 22, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
225 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
