Question about Car Audio & Video
Cd player and hot (high temperature) CD's
I have a 2005 Equinox and live in Houston TX. i keep CDs in the car and they get really HOT in the summer. I recently put a HOT CD in my cd-player, and the cd player, which had just been working, would not read the CD. I had the CD/radio replaced and was able to play a CD in it just fine. Then, I stupidly put another hot CD in it, and the brand new player did exactly the same thing - wouldn't play it.
Can a hot CD fry the CD reader?
  • 163 Answers
As with all electronics... anything can happen (even unexplained). There are two things to think abou tin this expensive experience.
  1. 1.CD's are made of plastic and metal... excessive temperature can cause them to warp, but not as bad as the old vinyl.
  2. Mosy electronics have an acceptable operating temperature. Although the unit may work outside these limits, it is not recommended. ex:My Sony DVD R/W has a range of about 40-95 F. Being in Houston I am sure the upper limit is reached OUTSIDE the car. Inside you are probably pushing 120+.
It may not be convenient but if you have to leave discs in the car, try putting them in a case in the trunk, out of direct sunlight. And let things cool down inside the car before trying the CD player.
I have not seen this before but like I said, anything is possible.
MM85
Posted on Jul 21, 2008
Help!! I have a library CD stuck in the CD changer. I can see it but it will not eject...it won't even acknowledge that it has a CD in the changer. I have tried tweezers, switching CD slots and trying to...
TRY TURNING OFF CD PLAYER.WAIT 10 MINUTES THEN TURN CD PLAYER BACK ON THEN PRESS THE EJECT BUTTON.SOME TIMES CDS PLAYERS GET HOT WHEN PLAYED FOR A LONG PERIOD OF TIME.MY CDS SEEMS GET STUCK WHEN I PLAY CD PLAYER LONG TIME.SOMETIMES IF CD DONT COME OUT .IF IT STICKING OUT JUST A LITTLE.TRY PUSHING BACK IN CD PLAYER THEN EJECT IT.THIS TRICK WORKS SOME TIMES.
Mar 11, 2011 | 2002 Ford Escape
The blower works and a/c works but no heat comes out
If the blower is blowing air just fine, but you cannot control the temperature, you need to listen to air coming from the vents while turning the temperature from hot to cold. If you do n ot hear any change in airflow, then you may a temperature door in the dash broken. this is becoming a common problem on the Equinox
Tech JK
Oct 11, 2009 | 2006 Chevrolet Equinox
Electrical Issue that started with the CD Changer '05 Equinox
i would say thats your problem sounds like the changer mecanism is sticking and staying engaged causing the battery to run down
Aug 15, 2009 | 2005 Chevrolet Equinox
CD player doesn't work. It blinks "DISC". CD is also VERY hot when I take it out. Thank you very much
My 2004 acura rsx cd player keeps ejecting my cds when i try to hear them. I will stay on 00 for about ten seconds before it ejects them. Can anyone help me with this problem?
Aug 03, 2009 | 2003 Acura RSX
The cd player gets realy hot and sometimes does not play or gives me an error. the guy at the auto shop said that it was because i was using burnt cd's. Is that even possible?
is it fitted near heater vent or hose?
its not about the burnt cd,s thats all a lie
it mabe the unit has a dry solder in it
they are cheap so just get a new one THATS CHEAPER THAN BURNING YOUR CAR if it gets too hot & shorts out your wiring system
Jul 17, 2009 | 2005 Chevrolet Equinox
Proper transmission level for 1999 Altima GXE sedan
it should be when the car is a normal operating temperture and it should be at the top notch where it says hot he should hve roughly put 4 quarts in it.
Dec 08, 2008 | 1999 Nissan Altima
2005 dodge ram cd player won't eject cd
the dealer told me not to use burned cds to long in the cd player. the cds are a little thiker then a regular cd. i had to not use the cd player for a couple of days. once the cd cooled down it cam back out and i havent had a problem since. Solution dont let burned cds get to hot
Nov 26, 2008 | 2005 Dodge Ram
CD player error
Try and remove the radio fuse for 30 seconds to cycle power to the unit and then try to remove them. Some of these units have a software issue and a reset can clear it.
Aug 29, 2008 | 2005 Chevrolet Equinox
Cd player console
I am a volvo s40 owner myself.
Try to eject all of the CDs at once. To do so keep the eject button pressed for a few seconds. this will eject the CDs one by one.
The temperature of the air conditioner is probably changing because of the outside temperature change. eg if the temperature outside is 35C and you set the temp inside at 25C it will come out cold air. if the temperature outside drops to 30C the air will come out hotter. you will notice that between summer and winter. the same temperature set will give either cold or hot depending on the weather.
in winter if you set it at 25C it will be very hot. In summer it will be cold.
Aug 04, 2008 | 2006 Volvo S40
About every 2 months our 6-disc CD changer breaks down and we have to have the whole radio replaced they said it comes from playing burned cds in it but it has even broken down with store bought ones. So...
I had the same problem i just decided to pull the whole thing out and get a new radio and single disc cd changer put in and so far it works fine.
Jul 26, 2008 | 2006 Chevrolet Equinox
Car Audio & Video Logo
394 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
