Question about Sylvania SRCD227 27 in. TV/DVD Combo
Tv won't stay on
Why won't my tv/dvd/v cr stay on?
  • 4 Answers
Check the power cord and make sure it hasn't accidentally been cut or if its detatchable make sure its all the way in
Posted on Jul 31, 2008
Won't Stay On TV MODE.
What I need to know aside from brand and model number is does the set have a button that changes this feature or the player?
Dec 21, 2012 | Televison & Video
My Samsung DVD/VHS recorder the DVD won't close after playing DVD
Never force it, just use the remote.
If it won't stay in, unplug the unit and wait a while.
I think we get viruses from the TV signal which might be temporary (hopefully).
Apr 24, 2012 | Samsung DVD-VR330 VCR and DVD Recorder
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
Only get black and white picture using vcr/dvd why picture
Hi There,
The most likely reason for this is that your connections between the DVD player are incorrect. This usually happens when a Composite cable is connected to one the Component input sockets on the back of the TV.
If you are are using a composite cable (red, white, yellow plugs), please make sure the yellow plug is not connected to a socket labelled Y, Pb/Cb, or Pr/Cr on the back of the TV or the DVD/VCR. The yellow plug needs to be connected to a VIDEO OUT socket on the back of the DVD/VCR and a VIDEO IN socket on the back of the TV.
Do not use sockets labelled Y, Pb/Cb, or Pr/Cr on either of them.
If you are unable to determine which sockets to use, please let me know the brand and model number of your VCR/DVD and confirm the model number of your TV is GV42L. I will then be able to draw you a diagram showing the correct connections to use.
Hope this helps.
Feb 26, 2011 | Vizio GV42L 42 in. LCD Television
Problem adding dvd to digital converter box/tv mix
tengo un control remoto universal sony RM-v210
por favor si save como progamarlo escribeme a
gracias anticipada.....
Aug 02, 2009 | GPX D1816 DVD Player
5 flashing light code,unplug CR board,now 8 flashing light code
If you put the "CR" board back on, the error code will once again be 5 blinks. Your problem is likely the TV's IK blanking circuit. The Kine driver ICs on the CRT sockets boards CR, CB, and CG need replacement along with a few components in the 200 volt supply to the circuit.
Feb 12, 2009 | Sony KP-51HW40 51" Rear Projection...
Monster Component Cable labled Y/Cb/CR to TV that has Input Y/Pb/Pr
Y PB PR is the analog version of the Y CB CR color space; the two are numerically equivalent, but Y PB PR is designed for use in analog systems whereas Y CB CR is intended for digital video.
Aug 31, 2008 | Televison & Video
Connect dvd player
can you please post the input/output specs of your tv/player? it will be much easier to help you if i know whats flying here. thanx
Jan 17, 2008 | Televison & Video
Sylvania SRCD227 27 in. TV/DVD Combo Logo
82 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
