Question about Whirlpool Duet GHW9150P Front Load Washer
Drain pump lift
Can you extend to drain line up to 8 foot obove the floor? Will the stock pump lift that high?
  • 57 Answers
Hi mate I dont think it would work because the pump would not empty out all the water then you would find your machine to be stinking the height of any machine hose should be at least 2.5 feet
Posted on Jul 22, 2008
    Genius:
  • 1,028 Answers
Don't think so but ck owners manual to be sure
How to replace PS pressure hose on 95 Buick Roadmaster
Remove or Disconnect
Coolant recovery tank.
ECM cover.
Serpentine belt.
Power steering pressure line at pump.
Catch oil in drain pan.
Power steering pressure line at steering gear.
The pressure pipe is the lower line at the steering gear.
Use a 18 mm crow's foot line wrench with a 2 foot, 3/8 inch drive extension.
Access line from engine compartment, between the rocker arm cover and front of dash mat.
Raise and suitably support vehicle.
Steering gear heat shield bolts and heat shield.
Power steering gear line clamps at steering gear.
Power steering pressure line from vehicle.
Install or Connect
Power steering pressure line into vehicle.
Power steering gear line clamp at steering gear.
Steering gear heat shield and bolts.
Tighten
Bolts to 6 N.m (54 lb. in.) .
Lower vehicle.
Use a 18 mm crow 5 foot line wrench with a 2 foot, 3/8 inch drive extension.
Serpentine belt.
ECM cover.
Fill system.
Bleed the system.
Inspect
For leaks.
To support the cradle while lowering it use a floor jack in the center of the rear.
yes, i would change both lines since you are there. no other disconnects.With the bolts removed it will drop about 4 to 5 inches. make sure the fronts are tight,take your time.
Mar 05, 2016 | Buick Cars & Trucks
Just purchases the DD50PC. Set the pump to continuous, hooked the hose to the slop sink in basement approx 8 feet, pump running fine but when looked at it the next day the pump had shut off and the tank...
The reason this happened may be two fold. Either the hose is clogged or the length of hose is to long and then has to go up hill into the slop sink. The owner's Manual says the pump is rated for an 8 foot lift. However, what I have discovered is that rating, does not take friction loss in to account.
Try moving the unit closer to the sink and shorten the hose about a foot or two. Actually, a floor drain would be perfect, if you have one in your basement.
Hope this helped you ad thanks for choosing FixYa.
Aug 07, 2011 | DeLonghi DD50P Dehumidifier
Bought a Delonghi dd50pc dehumifier last week for my basement and I have the hose going uphill and out a window but the pump always shuts off after 3-4 minutes, filling the tank instead. Now when I lay...
You really answered your own question. The pump in the dehumidifier only has so much water lift capacity. By trying to run it up and out, you have exceeded the maximum lift capacity. Using a floor drain or even a bathtub drain in the basement will probably work, as long as the hose is not to long.*
However, if you can use a floor drain, there's no need to use the pump function. You can use the continuous drain on the back of the unit. using the drain hose provided for that application.
*The 13 ft lift capacity noted in the Owner's Manual includes whatever length of hose you're using to get to the window. As there is some friction loss involved. But, they fail to point that out.
Hope this helps you and thanks for choosing FixYa.
Jul 27, 2011 | DeLonghi DD50P Dehumidifier
How to install a power steering high pressure line on a 1998 olds 88 regency
You will need line wrenches to get the line off the steering gear assembly (tight in there near the frame sub assembly) First you will want to remove the drive belt from the power steering pump. Then remove the bolts from pump to bracket and lift pump up. On back of pump, remove low pressure line and drain fluid into a container. Under pump, remove high pressure line, and push it downward toward floor. From under car, follow the line to the steering gear, ( the line may have a keeper clamp or two for stationary support to remove along the way) then detach. Installation is reverse of disassembly........Not fun, but doable.....Mike
Jun 22, 2011 | 1998 Oldsmobile 88
I have a Maytag dehumidifier M7DH45B2A, and want to connect a drain hose, as opposed to using the bucket as we always have. What kind of hose, and do I just remove the bucket and hook up to the same...
Unless it can be 100% gravity feed (1 inch drop per foot) you might need this:
Part: WPL8212501
Fits Maytag M7DH45B2A 496719-1.jpg (Click images to Enlarge)
Description:
Pump-drain
No. in Pack:
Additional info:
Dehumidifier pump assembly conveniently attaches the pump kit to you dehumidifier. connect a run hose to a nearby sink, pump, or floor drain. this pump will push water through a hose to up to 18 vertical feet for drainage through a window.
Stock Status: In Stock
Price:
This part is also known as:
8212501
If you can gravity feed it and can get a hose around the output pipe then any flexible hose will work that is slightly larger than the output pipe.
Jun 02, 2011 | Maytag M7DH45B2A Dehumidifier
How high can I pump up to a drain.
I have the same question....since I own a cabin with no basement floor drains. I have to pump my washer discharge to a main level drain.
To check the elevation needed, hook a garden hose to the discharge line and, after running the discharge end outside, raise or elevate the line using a line and tree branch to determine the height at which pump discharge quits. 33 feet equals appoximately 1 atmos or 14.7 psig.
Oct 05, 2009 | Roper Washing Machines
Error 4 in bosch nexxt washer
After browing a little more on this forum, I found the solution to my problem.
There was an hairpin stock in the rotating device that is located behind the front plastic cover.
Thank this website was very useful to me. Hope it can help someone else too!
Jan 13, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
OE Error
You do not have an "OE" error, it is actually a "DE" error. (Drain error) If after 5 minutes of drain time the pump motor RPM's haven't gone up the dishwasher knows that there is still water in the tub and throws the "DE" error. Often times the problem is the controller, but I have found more often that the problem is a long and/or restricted drain line. If someone had to extend the drain hose to reach a drain the extra resistance from the splice and pushing all the extra water in the long drain line prevents the dishwasher from pumping out within the time limit.
In some cases it is possible to correct this condition by first making sure the drain hose has a high loop to prevent siphoning, then running the drain line through the floor and into an open trap. (again, to prevent siphoning) Do not use extensions on the dishwasher drain hose supplied with the unit.
Oct 25, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Installing a Washer in basement
The top of the drain pipe that the washing machine drains in to should be about 3 feet off the ground. If the sewer pipe is higher than that you can either get a longer hose, or drain it into a sump with a sump pump that pumps it into the sewer pipe. If you don't have a sump, first try the longer hose and make sure it drains to a point higher than the sewer pipe (that would be the easiest) or cut a hole in your floor and put in a sump and sump pump (the most difficult).
Oct 08, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal De
