Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No sound from our WD-52525
After having watched TV just a few hours prior, we turned on the TV last night and had no sound. After trying to get it to come on, it started spurting a little bit of sound, but that's all we could get out of it. We have surround sound hooked up and that didn't work either. Can you help us?
    Problem Solver:
  • 9 Answers
Does the picture clear?if does,check the sound output from the earphone if it is clear,if the sound is clear the problem is in the audio amplifier
Posted on Jul 24, 2008
Lamp failure in WD-52525
i actually own this tv myself... that striking you here will only occur when the lamp does not fire. as far as lamp life i have found that mitsubishi has the longest lasting bulbs from my experience. i would check to make sure the connector on the lamp is seated properly into the other connector in the tv. if you know your lamp is 100% i would look at replacing the lamp ballast. ive had this tv for a few yrs now and love it.
Oct 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
No picture or sound
did you remove any covers,lamp or filter? unplug for a few and try again!
Jan 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a mitsubishi wd-52525- when i turn on the tv, it sounds as if something is stuck in the fan, no picture, but I do have sound.
the aliens laid eggs in your tv while you were sleeping. you have to destroy the television before they hatch. if you watch survivor they will hatch and you are doomed.
Jun 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
TV made popping sound and then shut off
You need to look in your owners manual for the telephone number and order a new bulb. It should cost about $200, but they will ship it overnight and minimize your downtime.
I've replaced 2 in my WD-52525 in the last 3 years, the first one went like yours did, very suddenly, with an audible POP!! The second one was preceded by an orange warning light, which the book says is a warning that the bulb has about 20 hours left on it.
To replace the bulb, UNPLUG THE TV, remove the left speaker screen, with a philips screw driver unscrew the bulb, pull it out by the handle, then replace it with the same type, in reverse order. This is a very easy replacement that does NOT need to be done by a service technician to complete.
Dec 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
I have a hitachi 62" LCD tv.when you turn the tv on,the power light flashes for a few seconds then the temp and lamp lights flash.The tv does not give any sound or picture.
When is the last time you changed the lamp? They only last 1-2 years, depending on hours used. If not then power supply capacitors would be next. Have it checked. Or buy a lamp in change it.
Dec 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi TV 52'
Mitsubishi gives this error , when it does not detect a video signal.....Check your wiring.
Dec 24, 2007 | Mitsubishi WD-52525 52" Rear Projection...
1 second red blink followed by 2 second blink on "status" led
there is a service bullietin related to this.. it has to do with a thermal sensor inside next to bulb..this sensor monitors the temperture of bulb... it says getting hot....this sensor needs to be replaced
Dec 04, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
182 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
