Question about Frigidaire FGR231A Gas Dryer
Gas Dryer The glow stick, Glows, but it seems like the gas isn't getting to it, or won't ignite??......can you help?
  • 50 Answers
There is a flame sensor that senses when the ignitor is hot enough to light the gas. If the flame sensor is bad the gas valve won't open. It also might be the valve itself. There are 2 coils that must open for the gas to get through the valve. If one of the coils is bad the valve won't open.
Posted on Jul 21, 2008
Samsung Gas Dryer model DV328AGW/XAA, not getting gas to ignighter,
Could be a defective igniter, thermocouple, or gas valve
Mar 06, 2017 | Samsung Dryers
My mdg308daww spins, the heat igniter, glows for about 5-10 seconds and then stops after about a minute it glows again. The igniter was tested ok, and the coils were replaced still the same problem....
Assuming the gas supply valve is turned on, I would make sure the gas valve orifice in your dryer isn't plugged up. If its not that leaves your gas valve not letting the gas in. Very rare though.
Sep 25, 2011 | Maytag MDG308DAWW Gas Dryer
Dryer won't light. Igniter glows, then turns off,
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Jun 25, 2011 | Frigidaire Dryers
Smelled mild gas odor after moving dryer. Replaced gas line connection. Still smell gas. Tried to tighten gas line have strong gas odor after running dryer. Does not seem to be heating
The gas valve should not be opening unless the glow igniter glows and sends a signal to the gas valve. I suspect a small leak in either the gas pipe or at the gas valve. You will have to get to the gas valve to perform a leak test. While the dryer is open, replace the igniter.
Jan 26, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Have a stove ,oven will not light, the igniter glows bright,but there isn"t any gas coming into the manifold, the model is MGR5755ADW
Sounds like a bad igniter. even though it seems to be working it may not be getting enough resistance to open th gas valve. 90% of the time its the glow bar that is at fault. Slight chance that the gas valve is bad. Hope this helps you. Let me know if you need more help. Do not touch the glow bar when replacing it.
Aug 10, 2009 | Maytag Kitchen Ranges
Dryer worked well until recently. Igniter glows
I would take a look at the gas coil solenoids. The gas coils are right above the gas valves. They are black electrical coils. When energized, the coils open the gas valves. If one or more of the coils is defective (bad solenoids), then the gas valves won't open and the gas cannot ignite. Because it's difficult to test the coils, it is best to replace both (all) of them at the same time. Sure hope this helped and best wishes.
Jul 28, 2009 | Dryers
check for igniter to be glowing, remove the plastic tab on the front panel an start the dryer
if it glows igniter is ok takes about 30 seconds to glow.if it glows is ok.
then check the thermal fuse for conitnuity an if it checks ok
then you have bad coils. replace the coils an ur done
May 26, 2009 | Frigidaire GSGQ642A Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
Sep 12, 2008 | Dryers
Roper gas dryer works intermittently!
suspect coils on gas valve if ignitor glows timer is working
Jun 30, 2008 | Roper REX3614KW Electric Dryer
Whirlpool Gas Dryer
Yes, that is most likely the problem. Once the glow bar igniter glows so hot, the switch opens & drops power to the igniter.(The radiant sensor has continuity while cold & open when a flame is present.) At the same time, by opening it redirects power to the valve coils allowing them to open & gas flow to the burner assembly. The dying glow of the igniter fires the gas. However, if your igniter glows, the radiant sensor is good. In this case, you'd need to replace the gas valve solenoids.
Aug 01, 2007 | Whirlpool LGR5644J Gas Dryer
Frigidaire FGR231A Gas Dryer Logo
103 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
