Question about Fuji FinePix A800 Digital Camera
How to disassemble?
I can't get the screws out? is there a special tool that is needed since the screws are not the typical phillips or flat? thanks, donna
This solution gave me the hint on opening the camera case w/o damage...gently prying the cover over the usb, a/v, and pwr connectors. FYI about finding the "tri wing" tool: I bought mine at Micro Center here in Dallas. You can go to www.prokits.com.tw and look up 89400-TRI tri-wing driver. It cost me $2.99 plus tax and worked perfectly.
Posted on Nov 20, 2009
Hi Donna, look up a trigram screw driver. I bought one on E-bay. The back cover has to be sort of prised over over the yellow a/v output. Also be careful of the two cables holding the screen on to the camera. The wide one can be taken out, there is a clip holding it on. The small one cannot be taken off. I broke mine, so a bit of a pain, as I'm now looking for a new screen. Oh joy.
Also if you are taking the next bit out, there is one screw hidden by the power socket. You have to really strain to get at it, as it is behind the item you are trying to get off. Get over that one and its all plain sailing.
Posted on Sep 19, 2008
I can't remove the backplate off my Neff B1421 oven
its a tamper proof screw at torx 20 size.dont undo with a phillips tool will ruin the heads and never get them out.
Mar 05, 2014 | Neff B1421 Electric Single Oven
Nespresso d300 leaking
The disassembly is a bit tricky as there are some screws with oval heads that require special tooling.
The web site below has tons of useful information on how to do it and where to find the special tool for the oval-head screws.
http://maultech.com/chrislott/blog/20100627_nespresso.html
The tool is available on ebay for about $10.
http://www.ebay.com/itm/Nespresso-Krups-Service-Repair-Tool-Open-Security-Oval-Head-Screws-/121114184054
I managed to disassemble it by cutting a slot for a flat-head screw driver in the oval screws using a Dremmel tool.
Most of the screws that you have to remove are on the back of the machine. There are three special oval head screws + four torx-head screws + two Phillips screws on the top of the machine.
Feb 06, 2014 | Nespresso D300 Espresso Machine
Biosremoval 595b
You will need to reset the BIOS. For this you will need to remove the keyboard, unplug the CMOS battery for an hour then reassemble. Tools needed are a small Phillips/star head screw driver and a small flat head screw driver or knife for the bezel if you don't have a pry tool. If you are confident to go ahead with this on your own, follow the instructions in the following link. http://www.ifixit.com/Guide/Disassembling+Dell+Latitude+D630+Coin+Battery+(CMOS)/13250/1
Sep 07, 2013 | Dell Latitude D630 Notebook
Replacing a fuse
do they look like allen screws or more like stars(torx)?
Dec 31, 2011 | Whirlpool MH2155XP Microwave Oven
Remington Electric Shaver..How do I disassemble a Model XLR 900. 8BF2-1C. I want to replace the battery.
Unfortunately these rechargeable razors are not designed to be easily serviced by the home user.
Changing the battery will definitely involve a bit of searching for the multiple screws which hold the case together and then disassembling the case to access the battery compartment. Just watch out for any screws which may be hiding under the rubber padding pieces. You will then likely be required to desolder the old battery out and then resolder your new battery back into place.
Here is a link to a site which describes the various methods for disassembling battery powered shavers:
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Here is a link to a replacement battery available for your model:
http://www.batteryweb.com/cordlessrazordetail.cfm?ID=238
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
May 14, 2011 | Health & Beauty
Key is stuck in igniton in 1986 corvette how to take key cylinder out and get new one back in
Two special tools are needed: steering wheel puller and lock plate depresser. Both available at auto parts store for $20 or less. This is how I got to mine on a 1987 Corvette. It has a special steering wheel, but this should work for you too. Pull steering wheel. Remove plastic cover (no tools needed). Depress lock plate with special tool. With 2 screwdrivers, or 1 screwdriver and needle nose pliers, pop the little ring out of the channel towards you. This ring was holding the lock plate down. Loosen the lock plate tool and bring lock plate out. Philips screwdriver to take hazard light switch off. One phillips screw holds the turn lever to the switch. Set the small metal arm and screw aside. Three philips screws hold the turn indicator switch (plastic ring). Carefully tug the switch towards you. There should be just enough slack in the wiring that you don't need to unplug it below the steering column, but it's close. Leave the switch dangling in front of the steering column. You're almost there! There's another screw that holds the ignition switch in. Remove that screw and the ignition switch. Replace everything
Nov 21, 2009 | 1986 Chevrolet Corvette
Is there a special tool to take off the rotor on the 1992 ford explorer 4x4
No special tool after removing the 4x4 hub the big nut in the middle has a flat metal pin that slides into a slot inside the nut you can remove it with a magnet then the nut will come off easy
Jun 25, 2009 | 1992 Ford Explorer
How easy to access the 3 screws?
Underneath. Don't see original post here, but to replace a pump (actually, just the pump motor) on an LG front load washer: Drain water out of small hose inside recess and remove access door cover (at lower left of machine). Remove one phillips head screw and use a plastic putty knife or similar tool to push in on left or right side of recess to remove the plastic recess cup. Now remove the two other phillips head screws visible. Tilt machine back and access pump Assembly from under machine. There is a tab that you will have to work loose. Disconnect electrical wires from pump at disconnect plug. You probably want to remove the hoses going to and away from the pump (squeeze clamps). Pump motor is easy to change out now with three more phillips head screws.
Sep 02, 2008 | LG WM-2277HW Front Load Washer
Drum bearings
Removal of the front seal (just the side right next to the door needs to be removed) is a spring loaded wire. There is a special tool for it, but it can be done without the special tool. Other than that, mostly phillips head screws and a few metric bolts. The suspension shock absorbers have a tab you need to depress to push them out.
Aug 19, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Fuji FinePix A800 Digital Camera Logo
194 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
