Question about Plantronics - Bluetooth Headset Plus Base & Headset
Can not get headset to charge - Plantronics - Bluetooth Headset Plus Base & Headset
  • 16 Answers
When it wont charge, there could be a bad cell on the headset, it may have suffered too many drops, or has been in contact with a lot of moisture.
Try to put the headset in a warm area, perhaps if you have a satellite dish receiver, cable tv receiver, or radio receiver in your house, sit it on top for an hour or two, and let the radiation from those devices dry out any excessive moisture that could corrupt your connections. This will not damage your headset.
If that does not work, I am afraid you will have to head to a local neighborhood wireless shop, or your retailer and get a replacement, or send in your warranty card and get it replaced with your supplier.
I would register your equipment on the website of your headset, then call them in for a exchange.
Please rate me for my effort.
Posted on Aug 07, 2008
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
My 340 headset will not turn on
Try these steps from the user guide and then pair up your headset to the phone. "Before using, you must first charge your headset. 20 minutes = minimum charge. 2 hours = full charge. Light is solid red when battery is charging. Press the control button for 2 seconds to power on. Press the control button for 3 seconds to power off." If you're still having problems, then it's time to get a new one, sorry.
Good luck from Headsets Direct!
Sep 22, 2011 | Plantronics Explorer 340 Wireless Headset
Ear peice wont charge from the charging dock
If it is under warranty (1 year) Plantronics will replace the headset and charging base case for you. Package up both the headset and the charging case and include your return address, phone number and a copy of your receipt and send to:
Plantronics ATTN: Service Center 345 Encinal Street Santa Cruz, CA 95060
Good luck from Headsets Direct - 800-914-7996.
Aug 24, 2011 | Plantronics Discovery 975 (8164001 P)...
The Headset Lifter won't pick up the calls. Nothing happens when I push the ear button to lift it up. I thought maybe it wasn't fully charged when I tried it yesterday. At that point, I made...
If the CS70 headset has a charge and beeps when you press the call control button, you may just need to re-pair or re-subscribe the headset to the base unit. Here is a link for the pairing / subscription instructions:
Plantronics CS70 Pairing Instructions
If the headset is not charging, the internal battery may be worn out and the headset may need to be replaced (the battery is hard wired and is not replaceable). The replacement headset is model 72910-01. Below is a link where you can purchase the replacement headset.
Plantronics CS70 Replacement Headset
Jun 24, 2011 | Plantronics CS70 Wireless Headset
I can't connect with my phone
Please follow the detailed instructions below for the proper pairing of the headset with your phone.
CHARGING
NOTE For the best user experience, keep your headset fully charged.
CAUTION Do not use headset while charging and do not connect the charger while the headset is in use.
POWERING
PAIRING
Step One:
Prepare Phone- Turn on Bluetooth For most phones, go to Settings/Tools menu and select Bluetooth or Connectivity and select "On."
Step Two:
Prepare Headset- Pairing Mode Begin with headset turned off. Turn headset on (hold call control button for four seconds until the light flashes blue) and it will automatically go into pairing mode, flashing red and blue.
Step Three:
Pairing- Add Headset to Phone For most phones, go to Settings/Tools
> Bluetooth > Search or Add a Device, then Select "220Plantronics." For passkey enter
0000. Headset will flash blue when paired successfully. It is now powered on and ready to use.
NOTE: Normally you only need to pair the headset and handset once. If headset has been previously paired with another device, follow pairing instructions below.
If headset has been previously paired with another device, please follow these instructions for pairing a second time. Be sure the headset is fully charged.
1. Press and hold down the call control button for 8 seconds until the headset status
indicator begins to flash blue then red.The headset is now in pairing mode for the next 120 seconds.
2. While the headset is flashing,use the phone menu to search for Bluetooth devices and select "220Plantronics."
3. When prompted for a passkey, enter 0000. Headset will flash blue when paired successfully.
NOTE: The headset can pair to multiple Bluetooth devices, but will only connect to one device at a time. The headset will automatically connect to the last device to which it was connected.
Please don't forget to rate me if satisfied.Thanks for choosing Fixya.Good Luck.
Jun 11, 2011 | Plantronics Explorer 220 Bluetooth Headset...
How do i charge my jabra bt150
Use the AC adapter to charge from a power socket.
The charging socket is located at the top of the headset (the wider end). When the LED is solid blue, your headset is charging. When the solid blue LED turns off, it is fully charged.
Sep 27, 2010 | Jabra BT150 Wireless Headset
Does the LG HBM-210 have to be on to charge
According to the instructions provided by the operator manual...
"Connect the charger to the charging port.
- When the charger is connected, with the power on or off,
the Headset will turn off automatically, and cannot be used.
While charging, the LED indicator will show a solid blue light.
- The buttons will not function while the device is charging.
- It takes 2 hours to fully charge the Headset.
- When charging is complete, the LED indicator will turn off.
Jan 20, 2010 | LG HBM 730 Bluetooth Headset Wireless...
Headset not charging
Sometimes it takes longer than two hours. Leave it plugged in overnight if you can. The indicator light should go off after fully charging.
Aug 14, 2009 | Motorola Mobility H500 Wireless Headset
Bluetooth headset
USING THE HEADSET
US USING THE HEADSET
1. Headset
2. Control Button
3. Light Indicator
4. Microphone
5. Earloop
6. Speaker
7. Charging Jack
A. Charging
Charge for at least 20 minutes before
first use. Complete charging in 2 hours.
Headset will not function when charging.
B. On/Off, Volume↑↓
Press the Control Button for 2 seconds
to power on. Press the Control Button
C. Pairing
Begin with Headset turned off.
Press button for 6 seconds. Release
button when Light Indicator flashes
blue/red. Headset is ready to pair with
Bluetooth device.
D. Pairing
Use your device’s menu to begin
pairing mode and select “320
Plantronics” on the display. When
asked for passkey, enter “0000.”
Jul 13, 2008 | Plantronics Explorer 320 Wireless Headset
Motorola H550 bluetooth headset
i turned it back intno the store got a refund and went to a different headset. sorry to bother you but i think it had to do with the battery in the headset
Feb 24, 2008 | Motorola Mobility H500 Wireless Headset
Plantronics - Bluetooth Headset Plus Base & Headset Logo
37 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
