Sometimes my inglis dryer will work fine other times it may not dry clothes completly then it would not work at all the two hours later it worked fine
Thanks for the question On those dryers what happens is the motor over heats and it will cut off on an overload protecter. the cause could be as simple as a lot of lint & dirt on the motor Give it a good vaccum should vac out the dryer every fall anyway it will run better try that if after you vac and it does it again Replace motor thanks for the question The appliance doc
