It is simple to change your treadmill so it reads MPH.
Treadmills are an easy and relatively inexpensive way of maintaining physical fitness. Most modern treadmills have a readout on their console that will track your speed over time in kilometers per hour or miles per hour. If your treadmill came with the wrong setting, it is possible to toggle between these two settings.
Instructions
Things You'll Need
hi,
Every 9,000 miles (14,500 km) the unit will show "SVC" on the display. This will continue until the service is performed and the service odometer is reset.
1. Determine mileage.
A. While in Dormant Mode enter Test Mode by pressing and holding the Heart Rate and Level keys simultaneously for five seconds.
B. Press the Dist key. DIST appears on the display. Record Mileage. NOTE: Once the unit exceeds 999 miles or kilometers the odometer will use both screens. Example:
12,805 miles or km would be displayed as 12 805 . NOTE: To exit Test Mode, press the Pause/Stop key .
Every 5,000 miles (8,000 km).
? Check running belt tension and tracking.
? Move treadmill and vacuum underneath..
? Lubricate elevation pivot points.
(Watch the videos for tentioning and lubricating treadmill belt.)
