Question about Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N750 Hi guys....Ned a Sony SLV-N750 Schematic. Does any one have it?
  • John Byse
    John Byse Jul 23, 2008
    I have been looking for months for one too. My power supply is dead. Any info would be appreciated.
    MM85
A common problem with the Sony SLV 700 series was the Mitsumi power supply (aka the electrolytic capacitors).
The metal box mounted in the middle of the complete power supply area fails. I encountered this problem about two years ago with my SLV-E730, it was just dead.
I did some Google searches and found quite a few people (who put some time into finding the problem) found that two of the Electrolytic Capacitors died. So rather than just replace two (after all the effort of getting into this tin-box), I took note of all 6 or 7, and replaced the lot (c153 ... c254). I figured that the heat in side the 'tin can' would have its effect on all of them (I tested a couple and they were down on the actual values). It was curious that some Cap's were rated for 85deg, and others 105deg, but I replaced them all with the exact same uF values (some slightly higher in voltage handling - 50v to 63v) but all at 105deg.
Then machine came back to life and has been as good as gold every since!!
I hate throwing things away especially when the problem cost less than $10 to fix....
Despite being old technology my children have 100+ tapes (very few bought) that they enjoy watching. This unit is so good at playback that you are not sure if a DVD is playing or a tape. I would not say these units are poorly built or disposable, it is just one component - aka the Mitsumi module used some ordinary Cap's.
Note: The metal box must be fully desolder-ed from the main board. That is 6 anchor points - the 4 inputs and the 8 or so outputs.
Posted on Aug 28, 2012
    Problem Solver:
  • 11 Answers
Check "SAMS" repair manuals.
Posted on Sep 28, 2008
Need new sony vcr remote
Try searching Curry's Partmaster website, if you are in the UK.
Mar 30, 2013 | Sony SLV-N750 VHS/S-VHS playback VCR
110 to 220 conversion
a converter plug should be fine
Jun 01, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony VCR ''Eats the Tape'' Model SLV-N750. It plays and records but doesn't release tape. It does not repond after I try to run forward or back and does not advance on ''Play'' but shuts off. Is there any...
If this unit is 4-7 years old then TOSS it. As time goes by the rubber gets soft and the units timing gets whacked. Repair will be more than what it's worth , unless your emotionally attached to it ...
Please rate!
Mar 13, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
CAN'T SET VCR (SONY SLV N750)TO CH 3 OR USE MENU
This is a link to the owners manual for your unit, click --->here<--- to download.
in brief, connect antenna, plug in vcr, turn on. if ch3 is not auto tuned, it can be manually set from the instructions in the owners manual.
Please take the time to give this solution a fix ya rating.
clarkco
Feb 16, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Take-up reel in Sony SLV-N750 doesn't take up.
The idler assembly is not engaging the takeup reel correctly. Examine the gearing between the hubs for debris. There are parts available for this deck, but it is difficult to say whether or not you actually need any. Check for the debris first and let me know what you find.
Dan
Feb 05, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
SLV-N750 compatibility with DTV signal
As long as your cable company converter box is feeding your VCR, you should be ok. The cable box should convert to analog which is what your VCR records.
Jan 19, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
My Sony SLV-N750 recorder works perfectly - except..
If the door is not connected to a "tape in" interlock
Jul 22, 2017 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N750 sound problem
befor i give u answer of this Q.i m gona ask u some think to make sure u regulur tape is orignal recoding from company is not that means u recrder vcr out of alighnment on audio head ..so chack that ....and hi fi system very sensetive about it,s audio head alighment ....or might u notice movie runs slow some time or fast ......if that kind problem u can't do much about it only u can do use the orignal record tape or alighment a audio head ...good luk...oh yaa clean head first ..
Dec 21, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Sony SLV-N750 VHS/S-VHS playback VCR Logo
322 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
