Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
04 1200 Sportster - backfires - cuts out - fouls plugs
Have had 2 dealer ships work on it - its been in the shop 3 of the last 4 weeks! Replaced crank sensor, replaced intake seal, rebuilt carburettor, and both shops have rejetted it. It starts after traveling less than 2 blocks and by the time I've traveled a mile its so bad it won't make another block without sitting for several hours!
  • Anonymous Aug 19, 2008
    03 sporty backfires fouls pulgs changed coil, wires, plugs
Turns out the crank sensor needed to be replaced again (second time in 8 weeks or so!). In the last week Harley has sent out a "improved" crank sensor that does not have the issues of the original. Therefore if you replace it once you shouldn't have to do it again and again. Bike runs great now. We will see - though - my local service manager promises it will stay that way.
Posted on Jul 30, 2008
Cutting out really bad
Hi, Kristy would help me a lot if I knew the year-make-model and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Cutting out and back fire while riding
Major missing backfiring cutting out when hot
Cutting Out BackFire when getting on throttle XR250 400
Engine cutting out while riding backfiring when get it to start up again...
Apr 23, 2016 | Motorcycles
My 2004 sportster xl883c backfires and misses even after its warmed up unless i leave the choke half way closed any ideas
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Harley Davidson Sportster error codes and how to access them
Nov 08, 2013 | Harley Davidson Motorcycles
My 2003 1200 sportster backfires starting from cold and is hard to start when hot
Hi Anonymous, and the usual supects are:
1. Spark plugs are in bad condition, improper gap, partially fouled.
2. Spark plug cables in bad condition.
3. Battery nearly discharged.
4. Loose wire connection at one of the battery terminals,coil, or plug between the Ignition Control Module.
5. Throttle controls not adjusted correctly.
6. Water or dirt in fuel system/tank
7. Water or dirt in carburator.
8. Intake air leak.
9. Fuel tank vent hose and vapor valve plugged, or fuel line closed off, restricking fuel flow.
10. Inrichner valve inoperative.
11. Engine lubricant to heavy (winter operation).
12. Ignition not functioning properly (possible sensor failure).
13. Faulty ignition coil.
14. Valves sticking.
For a possible prime suspect please visit the website below and good luck:
Sep 23, 2012 | Harley Davidson XL 1200 C Sportster Custom...
My 2006 harley davidson xl883c sportster backfires through the carb when i slow down or turn
For a prime suspect please visit website below:
Good luck
Aug 23, 2012 | 2006 Harley Davidson XL 883C Sportster...
Harley sportster 2000 1200xls backfires and sputters.
Jul 29, 2012 | Harley Davidson XL 1200 C Sportster Custom...
1998 sportster 1200, backfires and wont start
Jul 21, 2012 | Harley Davidson XL 1200 C Sportster Custom...
Harley sportster engine missing & backfiring
6. Damaged wire or loose connections at battery terminals especially the ground cable at BOTH ends, ignition coil, or plug between ignition sensor and module.
16. Damage intake or exhaust valve.
Harley Davidson Wiring Diagrams and Schematics
Mar 29, 2012 | 1993 Harley Davidson XLH Sportster 883
2002 sportster with stage one kit is starting but then backfiring and turning off?
Hi Telesia78, and the usual suspects are:
Mar 16, 2012 | 2002 Harley Davidson XL 1200 C Sportster...
I bought a 92 fzr 600 ride it for a month no problem. But now it keeps popping the resistor in the spark plugs. 3 sets of plugs in the last 2 weeks. Last set lasted 2 days. All have been ngk.
NGK plugs dont stop, especially all at once, so there is another problem.
There are some resisters in the plug caps that can fail.
Are the plugs carbon fouling?(dry black) if so make sure the air filter is new, and oil is changed.
Does the enginge blow smoke or use oil?(wet black)oil fouled may mean rings.
Fuel fouled may mean the jettting is wrong or choke stuck open
Its the battery good(new) and charging ,put a multi meter across the terminals 12v stopped, 14v running approx.
it always helps to drain the carb bowls every few weeks
If exhaust is not standard, the jetting may be wrong.
does the fuel tap work correctly? only use the run or res positions never pri
A short in the kill switch or a worn ignition switch can cause a miss or backfire
May 28, 2011 | 1992 Yamaha FZR 600
My harley sportster 1200 xlh 1990 seams to be running rich but i have now noticed that she is not fireing on the front cylender on initial starting but when it starts it cuts in what could this be have...
Hi Bennymullins, and the usual suspects are:
1. Plugs in bad condition, wrong type or number or partially fouled.
5. Battery nearly discarged.
6. Damaged wire or loose connections at battery terminals especially the ground cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
8. If your bike has a CKP sensor you must leave both plugs in
head and check for spark with a 3rd plug. Good luck and have nice day.Harley Davidson Wiring Diagrams and Schematics
Feb 15, 2011 | 2000 Harley Davidson XL 1200 S Sportster...
Lands Phones Logo
840 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
