I just bought a pc line microphone today. i have plugged it in and its not working
  • 682 Answers
Please confirm the following:-1-you put your plug in right place.
2-right click in speaker icon and open volume control confirm that there is no mute-check mic fader in up position.
Posted on Jul 21, 2008
I received my Asus HS-101 PC Headset today and plugged them in - I can hear sound though the microphone doesn't work for some reason. Any ideas?
You plugged both the headphone part in and the mic part in separately, right?
If you right-click on the speaker icon, you can select the "recording options". There may be a checkbox for "+20db" for the microphone as well as a volume slider. Try both.
May 14, 2015 | Radio Communications
Plugged in microphone not working
We really need more specific information to answer your question, like what kind of computer and operating system. But in the most general terms, make sure you are plugging your microphone into the microphone port and not the headphone port. Check that the volume setting is turned up and not muted. You might also have to turn the microphone on through the sound settings (usually found by right-click on the volume).
Feb 15, 2013 | Computers & Internet
Hi, I recently today bought a saitek GH20 headset. when i plugged it in the sound was fine. however, the mic is just buzzing hevily and is not working. ive checked my computer and my conputer isnt the...
you could try the following:
1. Enable it For Windows 7: Start> control panel> sound & hardware> sound> manage audio devices For XP/vista: Start> control panel> sound & audio devices> voice>
2. Disconnect the cables from the computer: restart the computer, then plug it back in 3. Check if you have the latest drivers(if applicable) on the Saitek website
Apr 23, 2011 | Computers & Internet
Trust headset HS2900 suitable for apple macbook?
On the MacBook there is no microphone port, if you look closely, it is not a microphone plug, it is a line in plug. Line in cannot record sounds from a microphone without amplification. What I would recommend doing is purchasing this adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812186035&cm_re=usb_audio-_-12-186-035-_-Product- With this adapter, you plug your headset and mic into it and then it plugs into the USB port on your MacBook. Then you can just unplug it from the USB port when you are done.
Feb 09, 2010 | Apple MacBook PC Notebook
Roland DR-30 Mic - how do you use it?
If the mic is a dynamic microphone, you would need a small mixer. The line input is a high level input and the mic level needs to be boosed. We here at Pro Line Music have small mixers 215-736-8055
Dec 26, 2009 | Roland DR-30 Microphone
Head phones will not work
Check you have Audio driver installed in yout Notebook and make sure your windows audio service is running by typing "services.msc in run prompt.
If all is in place.goto control panel and double click "Sound" and click "Recording" and check "Microphone" and "Line In",it should not display "Not plugged in".If that's the case,replace your microphone.
Again click "Playback" after plugging the speakers
Note :Sound card color code:
  Color Connector
  Lime Green Line-Out, Front Speakers, Headphones
  Pink Microphone
  Light Blue Stereo Line In
  Orange Subwoofer and Center out
  Black Rear Surround Speakers for 5.1 and 7.1 systems
  Gray Middle Surround Speakers for 7.1 systems
  Gold Midi / Game port (Joystick)
Dec 26, 2009 | Toshiba Satellite A135 Notebook
Bought the product today, installed OK but microphone not working
Go to windows Control Panel, click on Sounds and Audio Devices, and check under the "Audio" and "Voice" tabs to ensure that the recording device and the voice recording device are both set to the microphone that is associated with the webcam.
Joe
May 07, 2009 | Microsoft LifeCam VX-1000 Webcam
How to record audio using microphone input
What is the Make / Model of your Laptop? Depending on this, there may be an internal Microphone built into your computer you could use. If not, I can also show you how to specify windows use the "Microphone" as the input device.
Typically Laptops have 2 input selections "Line Input" and "Mic"
Line input is for use when you want to say.. Hook your ipod up to your laptop.
Microphone is a little different, as the input looks like the same as the other Line Input place, however the Microphone port provides power to whatever is plugged into it, which will cause problems if you plug anything other then a microphone into it.
And vice versa, if you plug a microphone into the "Line In" port, the microphone will not work, because the "Line In" port does not send out power to the microphone. Inside Windows Audio if you click 'Options' then properties, click on the recording tab, after this, make sure all the available check boxes ARE checked. Click OK. Then Find the MicroPhone Slider bar, Make sure it is towards the top, and also the checkbox marked "select" is checked. Then go back to Options - Properties - Click Playback, and ok.
Any other information you could provide will make for a better solution I will follow up on.
Mar 14, 2009 | HP Compaq Presario V2000 Notebook
Micro phone not working in my DELL Inspiron 6400
There is NO built in microphone with this laptop. You will need to purchase an external microphone and plug it into the mic in socket.
Aug 30, 2007 | Dell Inspiron 6400 Notebook
Microphone
my mic was never working i bought it today and pluged it in to my computer an it's not works when i talk in to it and yes it is on
Aug 25, 2007 | Philips PH62080 Uni-Directional Microphone...
20 people viewed this question
 Grubhead
Grubhead
