Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
Inverter problem where do I order an inverter board for an HP Pavilion f1503 flat (LCD) panel monitor (15 incehs monitor)
1800652667 as soon as hurricane Ike gets done with Houston, Texas. Or www.hp.com/go/support
Posted on Sep 13, 2008
My moitor is powered up but the screen is showing black. I can see very very faint words.what is the problem
chect your bright and contrast controls if they are ok
replace the cold cathode tube power inverter circuit board; it's under the center bottom of your monitor screen
Nov 18, 2013 | HP Pavilion F1503 15" LCD Flat Panel...
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Turns on but very dim
This is a 15 inch LCD. and the inverters of these units go south often.
If the unit does not flicker and you do not have a lose of power, it will be the inverter.
Oct 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My monitor is on then dims out
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
Oct 02, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Find out the power cable
here goes a link to the power cord
http://www.pdaaccessories.net/productDetail.asp?accid=935&searchcat=Laptop+Chargers
Feb 11, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Faint screen
try resoldering the ciols on the power/inverter board.
can also check for cold solder on output transistors and coil.
pd
May 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 LCD Monitor
If you can see the backlight ,white 2pin connectors connect to invertor pCB.Look around these two connectors you should see 2 brown/yellow/red transformers with a ferrite core.These are the inverter transformers , resolder all pins and power transistors around it.
That should solve your proble.
Please provide feedback and rate this solution.
Samir.
Apr 07, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 1503 15in Flat. screen blanks out constantly
THis is a problem of the invertor board.If you are technically able you need to disasseble the monitor and resolder components around the red or yellow inverter transformers.
Samir
Mar 04, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
LCD Monitor Repair
With the computer on and the monitor connected, shine a flashlight at a slight angle on the screen and see if you can make out a picture. If you can, then it is most likely the ccfl inverter, if not possibly the power supply of the monitor.
srich
Dec 10, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor problem
Check the cable wiring make sure all is plugged up right, If you have rebooted and it comes on ok than its the power cord. Remove and re-plug again
Nov 29, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
177 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
