Question about Vizio Gallevia GV42LF 42 in. LCD Television
Heads cut off on the screen
In watching some shows, the heads are cut off. Also, if there are subtitles on the bottom of the screen - I can't see them. However, if I select the guide and the channel I'm watching goes to a small window at the top of the page - then I can see the entire picture and the bottom of the page words - - but this is only while I have the guide up - covering the main portion of the page.
This is so annoying. When watching showtime - Ocean's Eleven last night to be exact - in certain times of the movie I could only see a portion of Brad Pitt's face - - c'mon - how awful is that.... HELP!
Are you watching with using time warner cable or an HDTV converter box? because if you are....on the bottom of your cable remote..on mine its the # button..above it says aspect...press that a couple of times and there are different zooms and stuff.
Posted on Mar 02, 2009
2 Suggested Answers
dsacco86
  • 1077 Answers
SOURCE: Heads cut off on the screen
Ocean's Eleven. Best remake movie, I think.
I believe your TV is in "ZOOM" mode for the screen. This will make a 4x3 picture come up closer to fill in the 16x9 screen, but this cuts off the top and the bottom.
Keep pressing the WIDE button on your remote until the picture looks best.
If you have HD channels, the screen mode should be on NORMAL. HD channels will have the 16x9 screen format.
The non-HD channels will have 4x3 screen format. When the screen mode is on NORMAL, you will have the cut off picture on the sides because the 4x3 format will not fill in a 16x9 screen.
Posted on May 30, 2009
Hitachi CLE-984 PROBLEM heads cut off on screen
You have it zoomed in.. There should be a option on the remote
Apr 10, 2014 | Hitachi CLU-5713TSI Remote Control
Heads are cut off on toshiba tv and reading at bottom
Depending on the model the set or a cable box may have an adjustment for this---simple thing to do also is hook to DVD player via rear inputs to see if same problem or not.
Apr 20, 2012 | Toshiba Televison & Video
Trying to watch a foreign film with subtitles (DVD). The subtitles are getting cut off at the bottom of the screen. TV is on full screen format (not Zoom). We tried moving the picture up the screen, but...
First, try the "Aspect Ratio" button on the remote. If none of the settings remedy the problem, try accessing the menu of the DVD player to ensure that it is set to 16:9 aspect output.
Let me know if neither of these help.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
Expanded screen
If it only does it via the coax or cable fitting it may not be the set.
Does it do the same thing when playing a DVD etc?
If problem is on all inputs it is a deflection problem in the set which for whatever reason has over scanned the picture to tall---it suggests a problem in the Vertical deflection circuit of the set (top to bottom is vertical deflection).
SD TECH
May 02, 2010 | Hitachi 57F500 57" Rear Projection...
May 30, 2009 | Vizio Gallevia GV42LF 42 in. LCD...
RCA D52W17 Picture is cut off at the top of screen
is it a black area on the screen? or just cant see the heads anymore? either way its proabaly a setting on the remote such as zoom or ratio
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Can't view entire screen
make sure that you tv is set to the "standard" format and then try changing the aspect ratio on the cable box.
Jan 26, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Heads cut off and no score...
Try your setting on your cable box (Screen position)
also maybe wide mode try switching to wide zoom good luck
Dec 10, 2007 | LG 42LC2D 42 in. LCD HDTV
Heads Cut Off
Is it in zoom 4:3 or zoom 16:9? Use the left/right arrows to change it.
May 06, 2007 | RCA D52W19 52" Rear Projection Television
Vizio Gallevia GV42LF 42 in. LCD Television Logo
471 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
