Question about Belkin Computers & Internet
Router My name is Joe my problem is the belkin router is a 1A359 it well not talk to the router. My laptop is asking for a SSID network #. I would like any help you can give me Thanks.
    Novelist:
  • 88 Answers
Hi Joe,
First, I am going to assume that you are running a Windows-based operating system, and my ideas are going to be specifically oriented towards Windows XP. If you use Windows 2000 or Vista, the operations I describe will be slightly different, so if you're not real familiar with those operating systems, let me know and I can send you revised instructions.
If your router is broadcasting its SSID (it's unique ID), which is an option in most routers, then your laptop should be capable of detecting it. You should have an icon on your desktop named "My Network Places". Right-click on it and select PROPERTIES. A dialog box should pop-up that shows your network connections. If your wireless connection is installed correctly, you should see i, possibly with a red "X" through it, which is OK. Right-click on it and select VIEW AVAILABLE WIRELESS NETWORKS.
Another dialog box should pop-up that will list all of the available wireless networks in your vicinity. You should be able to see your router in this list and it will likely have a name associated with the router's manufacturer (e.g. USR, Netgear, Linksys, etc.). It should also be the network that has the strongest signal since you are close to it. You should now be able to select it and then click on the CONNECT button.
Whether the connection process is completed successfully, you will see a notification of this. But before you do anything, bring up Internet Explorer and see if you can reach a website like www.cnn.com.
If the above procedures are not successful, then you will have to get into your router to obtain the correct attributes - or reset your router back to its original factory-set default parameters, which will be documented in their documentation. Unfortunately, Belkin does not reference a "1A359" router on their support site, so I don't know what actual model you have and can't give you specific instructions. Please look at the label on the bottom of your router to find the correct model #.
http://www.belkin.com/support/
Hope this helps! Please re-post if it does not or if you have other questions.
Posted on Jul 22, 2008
How can i install my wireless router to other laptop?
The same as 1st laptop.
1. Locate the wireless-network-connections option
on your computer or wireless device.
2. Select your Belkin Router from the list of available networks. You
can identify your Belkin Router by locating the network name
(SSID) from the card located underneath the foot of your Router.
3. Enter your network password (located on
your network information card).
Oct 06, 2012 | Belkin Connect N150 Wireless N Router
How do i connect ipad to belkin wireless router
..just look for your network name or ssid .. on the ipad.. if it will ask you for a password just type in your network key..
Dec 10, 2011 | Belkin Surf N300 Wireless N Router
How do I rename my network on a Belkin router
Please open the configuration page of your router by typing your router's IP address on a browser's address bar. Router's IP address is the default gateway when you check the IP address on the command prompt. As soon as you are on the login page, type the user name and password. Look for the wireless settings tab. SSID is the router's wireless network name. Replace the SSID of the name you want for your wireless network and apply the changes.
May 21, 2011 | Belkin (54G F5D7230UK4) Wireless Router
From I read online need to reset my belkin router. How doi reset my belkin router so I can use my laptop. The model number is F5D7234-4-BC v1
In the back of every router there is a little hole that is used to reset it. Sometimes is just colored different and some times it says reset next to it. It would be the only one. Just use a pen or paper clip and push in gently so the little rubber depressor does not break and hold it in for 30 seconds(make sure you do 30 sec on a watch nut quick counting). Router needs to be ON when doing reset. Once reset is done you might have to disconnect power to it for another 30 seconds but only if your internet is not working. Hope this helps.
Mar 13, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Just bought a new Compaq wireless laptop keeps asking me for a security key. Is this my provider or The Belkin router It's old and not been used for a few years model F5D9230-4
It is the router that you need to configure, to define:
* SSID (a "name")
* an encryption-level (use: WPA)
* a password/security-key
for your wireless network.
Then, you can connect to your network.
Oct 10, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Wireless connection to belkin g router model no. f5d7230-4
You need to access the setup page of the router using connected computer.
In your browser's address bar, type 192.168.2.1.
By default, leave the password blank.
On the Belkin setup page, go to Wireless.
Take note of the SSID. This is the name of your wireless connection.
Then go to Security under Wireless. Copy the network key.
On your friend's laptop, view the available wireless networks, you should see the SSID, then just enter the network key.
I hope this helps!
May 18, 2010 | Belkin (F5D7230-4) Router (587009)
Change the display network name
I am not quite clear if you want to change the Network Name or the broadcasted SSID (the information a wireless client can see).
I would change both, so a client or someone who wants to connect to your network can't see right away that you have a Belkin router.
First log into your router's web interface.
http://192.168.2.1(default), password "admin", username "admin" (als default) or follow the instructions on the screen, if you have never logged in before.
To change the network name, click on "LAN Settings" in the left pane.
Under "Local Domain Name", you can specify a personal name for your network. (I would always change the default "Belkin" so something else.)
To change the SSID, click "Chanel and SSID" also on the left pane a little bit further down. Here you can make changes to the wireless network name (SSID), operating channel, and encryption security settings.
Don't forget to save any changes you made!
If you need a manual, you can find that here.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Mar 19, 2010 | Belkin (F5D7633UK4A) Wireless Router
My friend came over with her laptop and wanted to get on our network. No problem right, she entered the eight digit PIN number and was immediately connected to our network. Then when I glanced at my own...
1 if its a belkin router then open ie or firefox
2. type 192.168.2.1 in the address bar it will lead u to belkin router setup page IMPORTANT --- U NEED A HARDWIRED COMPUTER TO ACCESS THE BELKIN PAGE
3. in the belkin page on the left side click on the wifi protected setup under wireless
4. login page --- leave the password blank click submit
5. disable the wifi protected setup and click apply changes
6. then click on the channel and ssid under wireless
7. change the ssid to ur desired name thts gonna be ur network name
8. check whether the broadcast ssid is checked marked or not
9. if its checked then click on apply changes
10. then scan and connect ur network it will not ask for the pin number and u will access the internet.
Feb 06, 2010 | Computers & Internet
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
My Xbox 360 Says No Wireless Network, 192.168 takes me to ask.com!
I believe you are referring to the network key set on the Belkinrouter. Since you do not have the code, you will have to access yourrouter's web interface.
Let's begin with your router:
Using your working laptop, open Internet Explorer type 192.168.2.1 (default IP address of Belkin routers) press Enter. It will ask for a username and password - by default it'sadmin for both. If it does not accept admin, type in the username andpassword you set to your router when you installed it for the firsttime.
Once you open the setup page of the router, go to the Wireless tab ofthe router (located on the left side of the web interface. Look forSSID and WEP key or Network key (SSID is the name of your wireless network). Take note of the SSID and WEP keybecause you will need to set this on the XBOX console.
On the XBOX:
Open the dashboard settings - select Network Settings. Configure your XBOX to connect to your wireless network. When it ask for the network key - type in the code that you will see on the router's web interface.
Try the steps I mentioned, give us an update and I'll reply ASAP if you need further assistance.
Good luck and have a nice day!
Sep 30, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Computers & Internet Logo
70 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
