Question about RCA TruFlat 27F520T 27" TV
Tv rainbow in screen
Have 27"tv rca has a big rainbow in screen , blue red and green
  • LILDIABLOWA Aug 08, 2008
    MY 52 INCH RCA BIG SCREEN HAS A RAINBOW EFFECT IN IT THAT MAKES THE PICTURE LOOK 3D. ALSO I HAD A RED,BLUE AND GREEN RAINBOW AT THE TOP OF THE SCREEN. HELP!!
    Scholar:
  • 104 Answers
The picture tube has become magnetized, possibly by someone getting a magnet to close to it. You can de-magnetize it using a strong magnet (cow magnet or similar). Place the magnet as close the the screen as possible without touching it to the screen. Starting at the middle of the screen and slowly (not too slow, about one full circle per second should do) move the magnet in a circular motion. With each full circle move the magent twards the outside (making a larger circle) as well as moving it farther away from the screen. Using a magnet will not harm the screen, so play with it and you'll soon get the feel and will see what you need to do.
Tv's have a circuit built in to 'Degauss' (demagnetize) the screen each time you turn it on, but this will only work if the set is 'Cold'. If the set is left off for 2 hours (to cool doen) and does not demagnetize when you turn it on the circuit is faulty.
Posted on Jul 21, 2008
  • 30 Answers
Take it to a TV shop that have a special Degausser coil and they can professionaly remove the spots. Also has the sete been dropped? If so the tube could be damaged
Posted on Jul 27, 2008
RCA 27V520T 27" TV has a red tint
Keep down the colour completley, and note whether you get a pure black and white picture. If not adjust the cutoff control, normally these are preset controls fitted on the base card of the TV; to adjust the excess colour seen on the screen to increase or decrease; so that you can get a clean black and white pocture with no tint on it. it is a time taking task; and should have some sort of skill and more patience. Sometimes you may have to retune other two cutof controls [Blue and Green], too to get the desired effect.
Oct 16, 2010 | RCA 27V520T 27" TV
What are the blue,green,red connections for?
These are the RGB inputs which connect in to give direct Red, Green, Blue inputs from one source to another, they will give a better quality of picture.
Nov 11, 2009 | RCA F27450 27" TV
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
Rainbow of colors on screen
I just had a rainbow of colors on my tv screen...i thought it was a problem with my TV...however the screen went the "sign off" screen (verticle lines-red/blue/green) Then all of a sudden the picture came back and all was back to normal again.
So I say it's nto your TV it is a station problem!
Aug 04, 2009 | Panasonic Televison & Video
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
The screen has a rainbow of red blue and green on bottom
The specs say this is a CRT type projection system, so it could be related to the display or to the TV. Since this has an SD card, it might be good to plug in the memory card with some pictures on it, and see if the problem persists with a source other than the tuner. That might at least narrow down whether you have a display failure/adjustment issue or something else.
Jul 04, 2009 | Panasonic PT-56TWD63 56 in. Rear...
Rainbow look on my picture
hit pictue tube w open palm if colors move crt shot.  if not magnatized need degaussing.  or defl youk loose.
Nov 30, 2008 | RCA 36F530T 36" TV
RCA CTC203 no red colour
Did you change the resistor by yourself? I am not sure if your TV has manual adjust on the back of the TV that you can adjust. Some times turning the TV Off and unplug it from the wall helps because it resets the TV. Check your Back ground color and see what is the dominating color. Blue, Green or Red. If this doesn't work please call a professional to look at it.
Jun 18, 2007 | RCA F27649 27" TV
RCA 25: television
Sounds to me like a bad picture tube with circle rainbow like colors.Good luck.
Sep 03, 2006 | RCA F25423 25" TV
RCA TruFlat  27F520T 27" TV Logo
1,072 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
