Question about Frigidaire GLEQ2152ES Electric Dryer
My dryer run but i get no heat
When i turn the dryer on i have no heat. i have replaced the heating element, the thermal limiter. I've metered the thermostat. I've double checked the voltage (240) and blown out the motor with compressed a
  • Anonymous Sep 15, 2008
    dryer runs but no heat
I replaced the thermister and it solved the problem
Posted on Jul 22, 2008
Roper dryer does not heat . replaced heating element and thermal fuse. what's wrong
No heat at all is usually the thermal fuse, the high limit thermostat, the heating element or you have a bad breaker at the box and are running on 1/2 phase (or 110 only).
With the power OFF and the dryer unplugged. Use and ohms meter (borrow one or pick up a cheap one for around $10-$15) & check the high limit thermostat (right hand side at the base of the housing for the heating element), take the wires off both terminals and check for continuity between the terminal (set the meter of ohms place the black lead on one terminal of the thermostat & the red lead on the other terminal, doesn't matter which, the needle should move, if it doesn't, replace the thermostat).
You can check all the thermostats, fuses, door switch & the heating element this way.
Feb 12, 2011 | Roper Dryers
Dryer not heating - I replaced the heating element and it still isn't drying.
  • Rank: Guru
  • Rating: 92%, 36 Votes
Yes there is a thermal fuse and a hi limit switch. The hi limit switch is attached to the heating element casing. You said the heating element checks out If you checked it with an ohm meter and it checked out good. If you checked it visually double check it. The hi limit can be checked with an ohm meter it should show continuity. If you dont have a ohm meter you can jump the wires by connecting them using a paper clip or copper wire. Make sure to tape them with electric tape. The thermal fuse is connected with the Heating element and hi limit by one wire and is located at the bottom back of the dryer and slightly to the right as you face the back of the dryer. It is a small two wire fuse and once it trips you have to replace it you can check it and test it just like the hi limit switch. Be careful and always unplug the dryer before starting any repairs. I hope this help. If you need me to clarify anything just let me know. good luck
Aug 25, 2010 | Whirlpool Dryers
A Kennmore electric dryer, model 697267. Heating element checks out ok. Soninlaw said breakers are ok. Dryer drum turns but no heat? I'm 640 miles away, is there a thermal fuse in the circuit.
Aug 25, 2010 | Dryers
No heat and believe it to be the thermal fuse on kenmore dryer 63
Unplug it, remove the back, f73a9b7.jpg1. Hi Limit (small limit upper right hand side of this pic) the most frequent problem if dryer RUNS but no heat AND you have
checked the element and found it to be good. 2. heater assembly.
3. 250f limit (if bad no heat, timer won't advance)
4. heater element
5. Fuse(350F), if blown(open) the dryer will NOT run.
(if you do not have a meter remove and inspect this heater coil for breaks).
6. control thermostat
7. heater (warms thermostat to shut it down faster for delicates)
Apr 13, 2010 | Kenmore 63942 Dryer
Dryer turns on, but does not heat up? is this the heating element?
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
***If the Thermal fuse is in good conditon, you will need to replace the element.
Jul 24, 2009 | Dryers
Dryer does not heat up. Power and element are ok.
Jul 18, 2009 | Dryers
Will not heat
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
Jul 16, 2009 | LG DLE7177 Dryer
Dryer runs too hot.
Remove power from the unit. You want to use a multi-meter set on an ohms scale. Remove the wires from each terminal at the heating element. Check resistance to ground at the heater by putting one meter lead to the case of the heater, and the other meter lead to each terminal at the heater. It sounds as though your element has gone bad and is shorted to the case. The resistance should be infinite. If you read any resistance from the element to the case, replace the heating element. The no heat setting should be exactly that....no heat.
May 22, 2009 | Dryers
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
118 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
