Question about Sony Cyber-shot DSC-W100 Digital Camera
MODE SELECTION PROBLEM
THE MODE SELECTION CHANGES ON ITS OWN. IT S INTERMITTENT BUT GETTING MORE CONSTANT. WHEN I TURN ON THE CAMERA, THE MODE SELECTION CHANGES BACK AND FORTH BETWEEN TWO OR THREE DIFFERENT SETTINS (EX: SET ON AUTO ADJUSTMENT MODE AND THE SETTING SWITCHES BACK AND FORTH BETWEEN AUTO ADJUST, PROGRAM MODE, MOVIE, ETC.) I DID AN INITIALIZE BUT THE PROBLEM STILL EXIST. ANY HELP WOULD BE APPRECIATED.
  • eileenshipma Aug 30, 2008
    Mine does the same thing but only goes from automatic to P.
  • Anonymous Aug 31, 2008
    I have a similiar problem and it randomly oscilliates from many modes.When I try to take a Video it goes into auto Picture mode.Can some one suggest a solution
Try menu-> setup->setup1, initialize, ok- this resets calendar and time as well. It brought mine back to correct mode selection.  Also make sure your battery is fully charged.
Posted on Sep 21, 2008
While in auto mode, I am getting a very delayed shutter reaction. Other times, it will not allow me to take a picture. The problem was intermittent and now is frequent. I have made no changes to the set...
hi there,
after read your explanation, i assume the problem is at the mirror. normally, the mirror will be weaken after 50,000 cycle times shutter and it`s the weakness of DSLR. it costs you nearly the price of the camera today, and i think it`s time for you to change it with the new one
hope this post will help, thanks
Jan 11, 2011 | Nikon D80 Digital Camera
Cannot receive fax - need to set up external TAD receive mode but gives error message "DR Mode in Use"
The machine should have a menu selection. Sometimes it takes patience and time to sit down and go through items to select.
Without having a manual to check, these menus should be available for one to make changes to the fax features.
Somewhere in the menu selection there should be a fax setup recieve and send mode. In that selection you should find the choice to make your changes.
If you do not have a manual, other than finding someone with a manual, this would be your best way to make the changes.
The vender might have the manual, if they do, it might be for a fee.
Good luck
Oct 17, 2009 | Brother MFC-3220C Plain Paper Inkjet Fax
Red dye reduction
You can find your manual here....www.olympus.co.jp/en/support/imsg/digicamera/download/manual/zoom/man_c725uz_e.pdf
You find how to disable red eye function on page no: 63 in that manual.
For quick reference i am giving the details briefly,
The flash modes are as follows:
AUTO FLASH:
Automatically fires in low-light and backlight conditions.
RED EYE REDUCTION FLASH:
This mode significantly reduces
the phenomenon of “red-eye”
by emitting about 10 preflashes
before firing the regular
flash. This mode works the
same as the auto-flash except
for the pre-flashes.
To change between flash modes:
1 Press the (flash) switch.
● The flash pops up.
2 Press the / (flash mode) button
repeatedly until the desired flash mode
indication appears.
● The flash mode changes ,
● If / is not pressed within 2 seconds after the selection screen is
displayed, the selection screen disappears.
● To de-activate the flash (Flash Off mode ), push the flash back into the
camera.
3 Press the shutter button halfway.
● When the flash is ready to fire, the
(flash stand-by) mark lights.
4 Press the shutter button all the way.
● The flash fires.
Hope my info solves your problem,
Thanx for using fixya,
Good Luck.
Sep 30, 2008 | Olympus Camedia C-725 Digital Camera
STUCK ON STANDBY
I took the ****** apart and found two spring-loaded black triangular plastic pieces poking out of two rectangular chips about 2mm square, just below the circular piece on the outside of the camera that changes mode – play, video, camera. Actually I found one of the above, because the second triangular piece was stuck in the closed position. A bit of jiggling and voila the problem was fixed.
That was the good news. The other news is that I must now reinsert inside of the shell a black circular piece of plastic that affixes to the rotating circular piece on the outside of the camera that changes the mode. When properly attached this circular piece manipulates the triangular pieces to change the mode.
I think that the likelihood of getting this piece properly aligned and affixed so that it moves the triangular pieces properly when the mode knob is rotated falls into the statistical probability range of pork taking wing. But worth a try.
Sep 04, 2008 | Fuji FinePix A345 Digital Camera
Wont take photos outside
The symptoms you're describing could be caused by either the "Fireworks" special scene selection mode, or manual mode with too much exposure compensation. Look at your mode selector (back of the camera, upper left hand corner). Is the mode set to the still image setting (pointing at the liittle red camera)? Or is it set to special scene selection (SCN)?
If you are unintentionally in SCN mode, to get it out of "Fireworks", just turn the mode selector dial to select "still image" (pointing at the little red camera). Or you can also select an SCN mode more appropriate for outdoors. Just turn the dial to SCN, press the FUNC button, then press the left/right arrow buttons to select Portrait, Beach, Snow etc...
But if your mode selector is already in still image selection, then check to make sure that you're not in "Manual" picture mode. Turn the mode selector dial to "still picture mode" (pointing at the little red camera), then press the "FUNC" button. Now look at the bottom of the screen. If it says "Manual", press the "left" button controller once to select and put the camera in "Auto" still picture mode.
Feb 29, 2008 | Canon PowerShot A400 Digital Camera
Flash mode locked to Off
Try this, I had the same problem. Here is what I did, I powered off the camera then with the menu button pressed I turned the camera on. This must set the camera back to default settings. I was then able to turn my flash to auto or any other selection.
Dec 28, 2007 | Olympus FE-120 Digital Camera
“My Mode”
My mode allows you to save customized camera settings. My Mode allows you to save different setting configurations. To use the “My Mode” settings, turn the mode dial to the icon shown. The My Mode configuration is selected by the menu selection Mode Menu > Camera > My Mode.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
“My Mode”
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
“My Mode”
My mode allows you to save customized camera settings. My Mode allows you to save different setting configurations. To use the "My Mode" settings, turn the mode dial to the icon shown. The My Mode configuration is selected by the menu selection Mode Menu > Camera > My Mode.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Sony Cyber-shot DSC-W100 Digital Camera Logo
64 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
