Question about Hotpoint Dryers
4 wire power cord connection - Hotpoint Dryers
    Scholar:
  • 50 Answers
The difference between a 3 and 4 wire cord is the 4 wire cord separates the ground and neutral, where the 3 wire grounds through the neutral. The 4 wire cord gives an extra safety against electric shock. The red and black wires on the cord go to the red and black wires on the terminal block. Then you have to determine where the green wire on the dryer goes, if it has one. Some dryers have the green wire spliced into the white wire maybe 6 inches from the terminal block. If this is the case you will hook both the green and white wires on the dryer to the nuetral (middle) terminal with just the white wire on your cord. Some dryers have a ground strap, a flat narrow peice of metal that goes from the neutral of the terminal block to the cabinet just below it. If this is the case then remove the screw securing it to the cabinet and bend it back up onto the nuetral terminal, or remove it completely. Then hook the green ground wire from the cord to the cabinet of the dryer. Make sure all of your connections are tight, but be careful not to strip them. It's also important to hook up the strain relief to prevent any possible tugs on the cord from pulling on the terminal block connections.
Posted on Jul 21, 2008
Illeagle
  • 525 Answers
SOURCE: I have a maytag dryer
A 4 wire cord should be hooked up accordingly:
1. Black wire to either outside terminal post.
2. Red wire to the remaining outside terminal post.
3. White wire to the center terminal post.
4. Green wire to the frame screw.
Also, make certain that your breaker/fuse box is wired according to local codes. If your dryer is not properly grounded through the fuse box and the green wire is attached to the frame then, a ground wire would need to attach to the green wire and then to an earth ground. This could possibly be your 5th wire, but you need to investigate it before applying power to the dryer.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
Greg20
  • 149 Answers
SOURCE: Replace a 3 wire power cord with a 4 wire power cord.
red on one end, black on the other, white in the middle, green to cabinet ground.
Posted on Jun 12, 2009
jsrock516
  • 5911 Answers
SOURCE: how to install 4-wire power cord
The following link explains how to install a power cord to an electric dryer:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Please note, if this is a new construction, you need to use the 4-wire configuration. If this is an existing residence that already has a 3-wire outlet, you can continue to use it configured that way.
The main difference between the two installations is how the ground and neutral wires are terminated. In a 3-wire configuration these two wires are connected together at the terminal block. In a 4-wire conguration these two wires are independent of each other and should NOT be connected together.
Read through the link provided and let me know if you have any questions. I hope this helps you.
Posted on Oct 10, 2009
  • 57 Answers
SOURCE: I have a Maytag dryer
The laws in most states are changing to where the NEC2.gif Code requires the use of this 4 prong plug. It is quite common to see this 4 prong plug installed in new apartment buildings and rental properties because of this law requirement.
So what you have is a red, black, white and green wire on the dryer side of this wire plug.
The red and the black wires are your hots (110 volts) and shall be connected on each outside screw of the drier electrical terminal and the white wire (neutral) shall be connected to the center screw.
So now you are left with an extra green wire with no place to hook it huh?
I suggest just loosing one of the drier electrical terminal mounting screws and hooking it there. The ideal here is to ground the outside body of this machine to prevent possibility of electrical shock if water is present (like a leak somewhere nearby).
In actuality this really serves no viable purpose because the white wire does exacly the same thing, just in a different manor,,, but hey,,, our law makers are not certified electricians either. They just like new ways of stimulating sales and profits.
Note: if you are in a rental property and this 4 prong wall receptical is installed, I would not suggest you remove it or change it in any manor, as this will open yourself up to possibile legal liabilities if an incident were to occur,, like fire.
Posted on Oct 11, 2009
Testimonial: "thank you! very, very helpful. dryer is hooked up and running!"
heatman101
  • 43501 Answers
SOURCE: the cord need to be changed from a 4 prong cord, 4
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Posted on Sep 21, 2010
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
How to replace 3 wire cord with 4 wire cord
On the back of the dryer where the cord connects, there are 3 terminals for the connection. The two outside terminals are for the power wires, the two colored wires at the edges of the cord. The center terminal is for the insulated center wire of the cord, the neutral, white in color usually. There is also a strap that may be connected to this center terminal, that should be removed and bent to the side, The bare or green wire in the cord connects to where that strap is connected to the metal back of the dryer.
Mar 28, 2010 | GE DVLR223 Dryers
Change power cord four prong fisher and paykel
The power cord for your dryer depends on the available receptacle. For a 4 wire cord connect the two outside wires in the cable to the two outside screw terminals , connect the center white wire to the center screw .. and the green wire connects to the ground stud , typically above the screw terminals.
For a 3 wire cord connect the two outside wires to the two outside screws ,., connect the centerr wire to the center screw and then add the ground strap from the stud above to the center screw terminal.
Dec 07, 2009 | Fisher and Paykel DGGX1 Electric Dryer
Jun 12, 2009 | Dryers
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
Replacing Power Cord Kenmore Progressive Upright
That actually sounds correct, if it's the model I'm thinking of. As long as you're talking about connecting to the wires that are held in by the wire nuts you should be good to go.
-R
Oct 25, 2008 | Kenmore 23613 Progressive PowerMate Bagged...
II HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL.
Your issue is as follows;
"iI HAVE A DRYER 4PRONG POWER CORD \. HOUSE OUTLET THREE PRONG NEDD TO CHANGE POWER CORD.DRYER INSTRUCTION CONNECT 4 TERMMINAL.WHAT HAPPEN WHEN CONNECT THREEN TERMINAL."
A 3 prong cord should be wired as follows:
1. 1 end of cord connects to 1 outside terminal.
2. The other end of the cord connects to the remaiing outside terminal.
3. The center wire connects to the center terminal.
4. A separate ground wire should be attached from the dryer chassis, then to a metal cold water line, or an exterior grounding rod.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
Jul 17, 2008 | Whirlpool Dryers
Unit trips circuit breaker when plugged in
On AC current it really makes no difference to the operation of the unit which terminal the wires are connected to as long as the circuit is completed. A reason for the inverted wiring is that there will be a resistance between the hot wire and the control circuit. It makes for a reduced load on the contacts and switches minimizing arching.
Jun 08, 2008 | Maytag Portable Air Conditioner M6P09S2A
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Dryers Logo
1,302 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
