Question about Insignia Car Audio & Video
Running 4 12s with two insignia 1000 watt amps
How can I get the best performance out of my system with two amps and four 12s
  • 1,586 Answers
Use a pair of two-channel amps that are two-ohm stable, and wire a pair of subs to each amp. Wire them in parallel so the amps see two ohms (wiring in series will show four ohms). Doing this effectively "doubles" the power of the amps. If the amps are not two-ohm stable, they'll fail. Parallel wiring means putting the positive wire of sub 1 to the positive terminal of channel 1 on the amp, and the negative wire of sub 1 on the negative terminal of channel 2. Do the opposite for the second sub. This will give you a LOT of bass response as long as your sub enclosures are properly sized for the speakers.
Posted on Jul 21, 2008
Deciding which car stereo amp to purchase
Both amps driving their rated impedance will consume about the same amount of power. If you connect the amp designed for one ohm into a four ohm impedance load, it will output less power than designed and also use less power. If you connect the amp rated at 4 ohms into a one ohm impedance, it will output and use more power but at the risk of having it burn out since you are over driving the unit.
Jan 21, 2014 | Alpine Car Audio & Video
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
How to run the speaker wires to connect to the subwoofer? and does a sub woofer burn if you do not put the right ammount of watts to it for example having an kicker l7 connected to a three houndred watt...
i'm guessing you are having problems with the dual voice coil's so I will link you to the kicker wiring guide...
http://kicker.com/sites/default/files/SoloBaricL72006.pdf that has the wiring options, you will need a pdf reader **** as adobe or foxit..
Under powering your subs won't hurt them but running a 15 inch l7 at 300 watts is not going to let the sub perform at peak, I would go with a 800 to 1000 watt amp.
15 inch l7 watt's are as follow
rms = 1000
peak = 2000
Mar 16, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
What to do
well i don't know your budget, but if that's not really and issue, right now at best buy, alpine type E, 10" subs, peak is 750w and rms is 250w, each is 129.99. Alpine type R, 10" subs, peak is 1500w and rms is 500w, each is 199.99. These are the best subs i found at best buy. You could sell your current subwoofers and purchase those, and you'd save space and still get the lows you want. Goodluck
Jun 27, 2009 | Jl Audio 12W7 Car Subwoofer
Will a JL audio 1000/1 amp run a orion HCCA 15
Hello evopower,
The JL 1000/1 will power the Orion HCCA OK.
It is stable only to 1.5 ohms so your best choice would be the 15.4 with dual 4ohm voice coils. In parallel, this would offer a 2ohm impedance. The 15.2 could only be wired for either a 1ohm load (too low) or a 4ohm load (less power).
Hope this helps.
May 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
Can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Feb 22, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
What is best amp to run 2 12 inch cvr's
12In Kicker CVRs
are Dual Voice Coil, and You can run each voice coil around 200 Watts RMS
So each sub will have a 400 Watt RMS and 800 Watts peak.
Now since you have 2, Your total will be 800 Watts RMS and 1600 Watts Peak.
I would get really any amp that sits at around 800-1000 Watts RMS.
These are kicker but they are low end so i wouldnt push them to the extreme.
1000-1200 Watts RMS Max and but keep the Gain down on the amp. They will hit no doubt but i wouldnt push these subs or you will be disapointed in the long run.
I would get a Fosgate or MTX amp.
You can get any amp really but find something right around 1000 Watts RMS and it will push those well.
You can go mono block or a 2 channel, just depends on how you want to wire them.
Be careful though. If your running them bridged right now with your mono block, do not run them parallel bridged on a 1000w RMS Amp, you will blow them so fast lol
(RMS = Root Mean Square. Or in other words is the continuous wattage being sent from the amplifier to the subwoffers)
Feb 15, 2009 | Kicker KX1200.1 Car Audio Amplifier
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Car Audio & Video Logo
484 people viewed this question
Top Insignia Car Audio & Video Experts
Mark Skinner
Frank Mangiapane
Level 1 Expert
Are you an Insignia Car Audio and Video Expert? Answer questions, earn points and help others
