Question about Panasonic Office Equipment & Supplies
I am a tech from NY I am working on a Panasonic UF-7000 fax with a J43 paper jam error code there is no paper in the machine and the registration switch is intact. Any ideas?
  • Paul Homuth
    Paul Homuth May 11, 2010
    Please leave the name of your company so i can search for it and i will call you
    Sergeant:
  • 284 Answers
The jam code normally means a bad fuser or one of the sensors under the toner cartridge
Posted on Jan 07, 2009
Panasonic uf-7000 error message: change battery.
Remove the chrome scew on the side of the dark blue op panel and pull out the battery holder. The battery CR2032 is available everywhere
Jun 10, 2010 | Panasonic PanaFax UF-8000 Laser Fax
I have a Panasonic DP180 with an error message J43
more then likely you need to replace the fuser unit
May 21, 2010 | Panasonic PanaFax UF-8000 Laser Fax
REMOVED PAPER JAM
There should be 2 switch actuators sticking up underneath of the toner cartridge, maybe one got knocked off?
Mar 30, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Paper Jam J43
One of the switches under the toner cart is knocked off.
Aug 09, 2009 | Panasonic PanaFax UF-8000 Laser Fax
ERROR CODE #021
Try a new toner cartridge. If that doesn't take care of the problem, it's the fuser.
Apr 08, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Panasonic UF-7000 Fax - paper jams and noise
Sorry to say you probably have a broken gear on the fuser assembly.
Very expensive to fix.
Mar 09, 2009 | Panasonic PanaFax UF-7000 All-In-One Laser...
Panasonic UF7100 J43 misfed paper error code
Did you pull out the toner cartridge and look?
Pull out the paper casstte, above that is a pull down access plate with a green handle.
Jan 08, 2009 | Office Equipment & Supplies
UF-8000 J43 Jam (Not There)
turn it around and have a look in the back panel that opens, open all other covers and check that any of the small black sensor levers are not stuck down they shoul all spring back
Apr 17, 2008 | Panasonic PanaFax UF-8000 Laser Fax
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
254 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
