Question about Maytag Dishwashers
Maytag Dishwasher Model #MDB7600AWB One of four plastic WHEELs mounted by screws to a 10 inch metal bar located on either side of the top rack has broken where the wheel meets the screw shaft. (These wheels run along the guide tracks for the upper rack mounted on the inside of dishwasher.) Please provide me with a part number so I can order a replacement part. Thank you.
    Sergeant:
    Champion:
  • 334 Answers
Call Maytag with information of the tag on machine
Posted on Nov 03, 2014
heatman101
  • 43501 Answers
SOURCE: the wheeels have broken off of my maytag diswasher
I think that this is the part that you are looking for....
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdb7600aws-%3d%3di1074716&PartID=1074716
Here is a tip that I wrote about buying parts online...
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Posted on Apr 12, 2010
SOURCE: 2 upper rack rollers cracked in Maytag #MDB7600AWS
JP Weld works great on repairing these junky Maytag parts. Note that they don't have a replacement for these upper wheels and a guy is selling expensive stainless steel replacements. The round connector broke off of ours that holds the wheel to the rack. My wife found a plastic button that fit within the space and we glued it with JP Weld epoxy (water and temperature resistant). 10 washes later, still working great! I expect it will "heal" any other plastic parts. NEVER will I buy a Maytag again!
Posted on Dec 14, 2009
  • 409 Answers
SOURCE: Maytag Dishwasher Model MDB7600AWQ
hi there,
please go to www.reliableparts.ca or .com depending on if you are in Canada or the US. you can purchase the parts from them.
Posted on Sep 23, 2008
SOURCE: broken casters (wheels)
This is definitely something that you can do yourself. Remove the back of the dishwasher and the front kickplate. This will give you access to the wheels. The wheels are held in place with a U shaped clip. Remove the clip and the wheel will come out. replace with the new wheel.
This happened with my Danby DDW1805 and I fixed it myself. I used two step stools at the side of the dishwasher to raise it off of the floor.
Posted on May 14, 2009
  • 10865 Answers
SOURCE: GE dsd 6700 top rack glider wheels not turning,
remove the tray and look at the wheels to be sure they are completely attached to the tray itself. If they are spray them with PAM or another cooking spray product to lubricate them.
Posted on May 18, 2009
Trying to get the top up on maytag model #mdg7400aww. Need to get some nails out that was left in pocket & dryed. can you help.
For the model washer you have listed, there should be a a couple of retaining clips inside the front seam where the top panel meets the washer front. If you push a putty knife in the seam about 2 inches in from each side, you will be able to depress the retaining clips to release the top panel. With the retaining clips released, the top panel will open up exposing the mounting screws that hold the washer front in place. Remove the mounting screws and the entire washer front can be removed, giving you full access the washer interior. If you have any questions let me know. I hope this helps you.
Nov 27, 2009 | Maytag Dryers
HOW TO I GET INSIDE A NEPTUNE DRYER MODEL 9700 TO FIX A FUSE
Unplug the unit.
Remove the top panel(two bolts in the rear metric 10 or Phillips will work) There are four screws across the top front of the control panel remove those and the panel will swing out and down,move it back and forth while pulling upward it has plastic clips on the bottom that keep it in place.follow the wires from the panel to the control board and unplug them or you can just lay the whole panel on top of the unit.
Open the dryer door and remove the two phillips screws on either side at the bottom of the door opening,then remove the four screws across the top of the panel it will lean out toward you,unplug the door/light switch and lift the front panel off the bottom clips.
You're probably looking for the thermal fuse located in the plastic elbow of the blower housing at the bottom of the unit it will be the round metal disc with a brown or black plastic backing.check your vent going outside and make sure it is completely clear/open doesn't have to be spotless clean but if it gets restricted in any manner it will blow this fuse.
Sep 13, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
2 upper rack rollers cracked in Maytag #MDB7600AWS - cant find simple replacement rollers for inside track - 1 1/4" - of upper rack.
Sep 11, 2009 | Maytag 24 in. MDB7600A Jetclean® II...
Upper rack roller replacement on mdb7600awd
go to www.searspartsdirect.com and search model # mdb7600awb, track and rack assy, this will give you the parts breakdown and you can order as needed. if you don't feel comfortable changine these components yourself, call a&e factory service, or www.aefactoryservice.com, these guys are cheap and good. jordanservices inc. doesn't yet serve your area, hope we could help :)
Jun 25, 2009 | Maytag MDB7100AWB Dishwasher
Maytag portable dishwasher, dish racks are very rusted in 2 years
This is Maytags solution
Do the dishwasher racks have chips or scratches showing exposed metal underneath?
If minor rack repairs are needed, a dishwasher rack repair kit just might work. To review this product or purchase the kit, click here.
Should you purchase the kit online, enter Promo Code F9A75Q4 in the Review Order screen when you check out to receive a 10% discount on your order.
For more severe rack damage, a replacement rack may need to be purchased; call the Maytag Customer eXperience Center toll-free at 1-866-616-2601, Monday-Friday, 8AM-6PM, Eastern Time.
I would call the toll free number and see if a free replacement is available. If not at least try to get a big discount on replacing them.
Good luck and thanks for using Fix Ya, please take the time to rate this solution (from Fix Ya, not Maytag, I didn't like their solution).
clarkco
Feb 05, 2009 | Maytag 24 in. PDC3600A Built-in Dishwasher
Need side mount brackets gpf65 because of granite counter top, model #ghda485n10cs ser# rm763786b, quietpower3 dishwasher
I don’t know your counter situation, usually you have to put dishwasher in a bottom cabinet and mount both side. Suppose you only have one side to mount, you have to go to home depot to buy a 90 degree metal mounting bar, mount the top part to your top granite support board, the bottom side mount to the dishwasher, it should be a ¾” plywood board underneath the granite, you can use ½” screw to mount it.
Hope this can help you,
Jun 25, 2008 | GE Dishwashers
Trying to replace broken upper rack adjustment arm . . .
first off check to see if there is an endcap either the front or back of the track. if so remove the cap. check for end mount screws. if no screws the endcap opens up the route for popping the plastic cover off and exposing the screws.. see diagram(may not be exact model but it gives you an idea)
May 12, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Mouse inside dishwasher
I have an MDBH945AWW.
I FIXED IT! They are getting in thru the water inlet/vent in the lower bottom left of the dishwasher. Here's how we fixed it:
1. Turn off water to machine if possible. Open the door, remove screws on side and top that hold dishwasher in place. Pull the dishwasher out from under the counter. Remove racks from inside.
2. Remove the sound insulation blanket. Mine was a mouse nest so I threw the thing out. Not going to replace it as the noise increase is minimal.
3. On the left side of the tub outside there is a tube that comes from under and is hooked to a small plastic box with an open top. THIS is the point of entry!
4. Poke a long screwdriver or something down into the box and pop the plastic tension prongs free. Reach into the dishwasher and remove the circular plastic grill.
5. Twist the plastic box to the right or left until the tabs line up and it will pop out of the side of the tub. Remove the tube from the box. The box should now be free.
6. Cut a square of 1/4 hardware mesh cloth (flexible metal grid) and cut a hole to fit over the nipple for the tube. Put mesh over the top of the box, secure in place with really heavy duty tape. Something strong like Gorilla Tape or even metal tape for ducts.... conventional duct tape will not hold after a year or so. I taped all around the edges and sealed it down only leaving the top with the mesh exposed.
7. Put the tube back on and then reinstall the box and then the grill.
8. Take this time to SUPER CLEAN the area under and around the dishwasher. Even the outside of the washer. Mice return to the smell of their poop.
9. Put the washer back in and don't forget the screws as well as turning the water back on.
$5 fix or a $500 new machine... you choose!
Oh yeah, and I'm a girl too...
:D
Tracy
Feb 01, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
220 people viewed this question
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
