Question about Kenmore Dryers
Button stuck in kenmore 110
Hi! There is a button stuck in my dryer. I can feel it at the edge of the drum but I can't get it out. I've been working on it with a needlenose plier, but no luck. It's a little round metal button. Can I increase the gap of the drum and the dryer at all?
  • amytri Jul 29, 2008
    Thanks!
    Genius:
  • 1,028 Answers
May try pusing up on drum but best bet remove front ..remove 2 screws under filter ..press clips in at front corners lift top remove screws each side of front panel let panel lean forward button should fall out if not lift panel up and remove completely
Posted on Jul 22, 2008
I have a kenmore 90 gas dryer modal # 110-77904792, the dryer gets power but wont start when you push the power button, it makes a humming sound?
possible could be the drum motor depending on type of hum. if a motor is trying to start sometimes will make that sound
Feb 09, 2012 | Kenmore Dryers
Stopped working. Circuit breakers are not tripped, electrical plug in all the way
Hi and welcome to FixYa, I am Kelly. After this post I will need your dryers' complete model number For now check the door switch. As you just open or just close the dryer door, listen for an audible "Click" as in a micro-switch clicking sound. No click = door switch problem
Also open the door and turn the dryer drum by hand. It should also be turning the motor as you rotte the drum in both directions. I you can not feel the motor rotating or... it rotates in one direction but not the other there is a belt problem. The drum should not easily turn 360 degrees.
Check the door switch and check the belt. If after this is is still dead... there is more that can be done but, I need a complete model number for further comment. The model number will be 3 digits followed by 8 digits 110.++++++++
Thanks for choosing FixYa,
Kelly
Dec 15, 2010 | Kenmore 60172 Electric Commercial Dryer
When i push the start button i can hear and feel the timer working yet nothing else happens. when i release the start button the timer quits working.door switch is working. i've checked all the connectors...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 06, 2010 | Kenmore Dryers
Clothes get tuck on the front edge and discolors
it most probably needs to have the felt cushion on the front of the drum replaced.
Jul 09, 2010 | Kenmore 83042 Electric Dryer
Dryer does not heat up
I would remove and clean the vent pipe on the back of the machine. There could be blockage inside causing your dryer to have little or no airflow(Check with vent not hooked of for a few min and see. Also make sure that your washer is spinning your clothes damp dry before you put them in the dryer. The rattling could be from any number of things. Check inside make sure there aren't any items stuck inside the drum or along the edge of the drum.
I hope this helps if i can help with anything else please let me know.
Mar 30, 2010 | Kenmore 73952 Gas Dryer
Kenmore elite 110 62974100, it heats up and the
kenmore dryer elite he model 110- runs but has no heat
Oct 08, 2009 | Kenmore Dryers
Drum not turning properly
Check the belt and see that it is not worn down, kind of like a fan belt on a car. You may want to replace it anyway. next, the motor be be loose from the frame it is fastened to. Feel the surface of the drum for any grooves or worn places. There may be build up of debris. You can take off top of dryer to gain easier access to the drum.
Jan 12, 2009 | Kenmore 659 Electric Dryer
Kenmore gas dryer will not start model 110 72972109
check your motor relay under your control panel
Dec 23, 2008 | Kenmore 62802 Electric Dryer
Drum light goes on and off kenmore elite oasis dryer
repl user interface ,, it has a stuck button,, order inter face
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Parts of clothes get stuck in edge of dryer...seems to burn them.
I have had this same problem with my stack-able dryer. It was leaving small burns on my kids clothes and my good sheets. My dryer has a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer can get caught and scorched or torn in the space between the clothes drum and the front of the dryer interior. My seal was worn out, so I needed to replace it. I had someone come in and do the work the first time but when it wore out again I just order the part and replaced it myself. It is fixable:)
Apr 07, 2008 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
44 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
