Question about Sanyo PLV-Z4 Multimedia Projectors
Replace lamp warning light goes on after raplacing it with the new lamp
After a shortage of electricity the replace lamp warning light started to blink yellow. I have replaced the lamp but same warning goes on and projector do not function. Is there any other solution to run my projector?
  • Anonymous Mar 21, 2014
    Lamp light blinks green,lamp does not light up its a sharp xv17000
  • Anonymous Mar 26, 2014
    After cleaning filters and replacing lamp there is no power or lights on the projector :-(
I had the same problem. There is an internal reset button just above the lamp that needs to be reset. You have to take the cover off, which would void your warrantee, but it's quite easy. My lamp only had 660 hrs, and I bought a new one too. So now I have an extra. My guess is that my filter was getting clogged causing an overheating situation and tripping this reset button which I'm guessing is a heat sensor.
Posted on Aug 26, 2008
2012 cbr 1000 check engine light 2 slow 3 fsst
warning lamp some used for warn low oil pressure, etc.
Wtith the bulbs use for most warning light circuit it is hard to determine whether or not the filamente is good. Will be a good idea to replace the bulb.
For test the faulty warning lamp, turn the ignition switch to START, this light the warning lamp. I f the light does not come on , disconnect the sender switch lead. . Use a jumper wier to connect the sender witch lead to ground. With the ignition in RUN the warning lamp should light. If the lamp is illuminated replace the sending switch. If the light does not come on,either the bulb is burned our or the wiring is damaged.Use test light for confirm voltage is present at the sensor terminal connector. If there the bulb is bad.
God bless you
Oct 05, 2012 | Cars & Trucks
97 lincoln mark viii oil pressure light always on. oil pressure good. new sender
test the faulty lamp , turn on the ignition switch to the START position The providing circuit shoudl ligh the warning lamp. If hte light does not come ON during the porve/out, disconnect the sender switch lead. Use a jumper wire to connect the sender switch lead to ground . With the ignition in the RUN position, the warning lamp shoud light. If the lamp is iluminated, replace the sending swith. If the light does not come on, either the bubl is buned out or the wiring is damaged.
God bless you
Sep 28, 2012 | Cars & Trucks
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Oil light flickers when in idle. Oil on dip stick measures fine.
install a mechanical guage to test the actual pressure, if its fine the sending unit is faulty, if nor remove the oil pan and check the oil pickup for blockage,
May 24, 2010 | 1999 Chrysler Concorde
Side lights won't come on
you have an electrical shortage. Have OBD analysis done and preform probe test lamp procedure on fuse box
Apr 25, 2010 | 2001 Volvo V70
Indicators do not work Although al lamps light when locking Car
Hazard warning light switch fault.
The hazard light warning button in the middle of your dash is actually a relay that often fails, causing this problem. New switch required.
Jan 12, 2009 | 2000 Audi TT
Lamp replacement
Hi there
There is normally a sequence of buttons on the Projector that needs to be pressed ! What make and model do you have ?
Sep 16, 2008 | Panasonic Videoprojector PT-LM1E...
PLV-Z1 no longer powering up - Ready light is green and the Lamp light is red
I have a Sanyo XU35. Mine was starting up and showed a picture for about 15 - 30 seconds then shutting down. My lamp warning light was not coming on. When I put it in for repairs it turned out to be the lamp that needed replacing. The technician said it is not uncomman for the lamp to be gone and the lamp warning light not to come on. I got my lamp on e-bay from ping_ngo for a great price.
Aug 11, 2007 | Sanyo PLV Z1 Multimedia Projector
Sanyo PLV-Z4 Multimedia Projectors Logo
1,036 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
