Question about Minolta Office Equipment & Supplies
I have a c500 error on my Minolta EP4233 copier. Do you what what error this is?
  • Minolta Master
  • 6,117 Answers
The fuser is bad. I don't even know if the make the parts for series anymore. Could be a bad lamp thermistor or heat sensor.
Posted on Dec 28, 2014
  • 11 Answers
SOURCE: Minolta Copier
  • STARTAER get low
Posted on May 07, 2008
acdr
  • 1913 Answers
SOURCE: error code 29-16 on minolta
connect your printer us b cable again to computer.
also check there is not any paper jam on printer.
also refix cartidgev again.if problem remains check u installed driver properly.download driver from here and remove first old driver then install printer driver from here.
press power buttton for 10 seconds.also refix your ram after clean dust from it.
Posted on Nov 27, 2008
Cogz
  • 1326 Answers
SOURCE: Describe your Minolta Di3010 Grayscale CopHi I
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
Posted on Jun 27, 2009
SOURCE: ERROR CODE SC45-20 MINOLTA 500
transfet belt off alignment
Posted on Mar 11, 2010
hamzaskilltd
  • 316 Answers
SOURCE: error sc23-09 minolta bizhut c500
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Fuser problem, Warm-up incomplete
Posted on Jun 13, 2010
SMTP setting in Bizhub C500
Go to Self Help Product Support Konica Minolta Business Solutions Inc you can get pdf file of the operation manual so you instructions on how to do that. Can also contact them
Feb 26, 2014 | Konica Minolta bizhub Office Equipment &...
Copy is coming plain black
DEAR fRIENDS NEED HELP TO FIX MY COPIER KONICA MINOLTA BIZHUB PRO C500 ERROR CODE C45-02 PLZ.
TeleFax: 966-12-65o3104, Mobile No. 00966-502835548 / 00966-565339421 / 00966-540556951 e-mail :- uec_it@hotmail.com
Dec 15, 2013 | Kyocera TASKalfa 180 Copier
Bizhub 211 error code c500
ihave error code c5oo c501 in bizhub 211
Jan 16, 2013 | Toshiba E-Studio167 Copier
Error sc23-09 minolta bizhut c500
Jun 13, 2010 | Minolta bizhub 200 Copier
Porque sale error c0500 en la dialta 470
plz chek the thermostate heater unit fuse and heater lamp and clear truble button and relase this code c500
May 28, 2010 | Konica Minolta DiALTA Di200 Copier
Color registration problem Restart copier and leave the front door open,will bypass the error code page.Press HELP,then press KEY OPERATOR MODE, scroll down to 21 EXECUTE ADJUST OPERATION, select COLOR REGIST AUTO ADJUSTMENT, then press OK, PREVIOUS SCREEN. After adjusting, it will back to normal. If the code number back on again, then it was the transfet belt off alignment. If you know how to pull the transfer back to center position, problem solve, if not, call technician.
Feb 11, 2009 | Konica Minolta bizhub C250 All-In-One...
ERROR CODE SC45-20
HAVING A REPORT CODE SC 45-20 HOW TO SOLVE IMMEDIATELY FOR PRINTER/COPIER BIZHUBPRO C500
Minolta Dialta620 copier error code c-0000
Code C0000 if a fuser motor failure.
Check to see if anything is damaged in the fuser (the thing that gets hot).
Also, check for a jammed transparency (if you use them).
Feb 10, 2008 | Minolta DiALTA Di620 All-In-One Laser...
64 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
