Question about Lite On Televison & Video
My disc tray does not open or close - Lite On Televison & Video
Use a small pin or needle and keep pushing gently to eject the door of your cd make sure you dont push the needle or pin hard keep pushing either of them intermittently.
Posted on Apr 26, 2009
How do I unjam a disc stuck in the 5xCD tray of a Sony DAV-C770 compact AV system?
If you experience difficulty with the disc tray opening or closing, follow these steps to try to resolve the issue.
  1. Turn off the power to the disc player or the stereo system, if the disc player does not have a separate POWER button.
  2. Unplug the power cord from the AC outlet.
  3. Verify there is nothing is blocking the tray from opening or closing.
  4. Let the disc player or the stereo system remain without power for approximately one minute.
  5. Plug the power cord back into the AC outlet.
  6. Turn on the power to the disc player or stereo system.
  7. Attempt to open or close the disc drawer or tray.
If the issue is still unresolved, service may be required.
this is direct from sony hope it helps
Dec 31, 2014 | Sony DAV-C770 System
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
Hi, the dvd on my recorder stayes ejected? It will close but then will eject straight away? What can I do? Cheers.
The fault is not from the disc, it is from the player.
The disc tray is actually malfunctioning. Which is as a result of a fault on the mechanism that is controlling the opening and closing of the disc tray.
Another fault might be that the button that controls the disc tray might be stuck.
test if it is the button.
  1. Unplug the player from the power source,
  2. plug it back,
  3. turn it on,
if it opens without you pressing the open button, then the fault is from the button.
check it for any irregularity.
  1. get the appropriate screwdriver,
  2. open the cover of the player,
  3. carefully force the front control panel open from the sides,
  4. then check for any damages,
  5. change the open button and it will be okay again.
test if it is the disc tray
press the open button, if it opens closes continuously.
then there is a problem with the mechanism that controls the open and close of the disc tray.
to fix this,
  1. Get the appropriate screwdriver,
  2. open the back cover of the player,
  3. look to the left side of the player and you will see a mechanism that controls the tray,
  4. change the mechanism with a new one.
after doing that, the player will be in good condition again.
take care
Jun 18, 2010 | LG RH1777 DVD Recorder
My xbox will not read discs it just says open tray
I found a solution that works for me after a long period of time with this problem.
Get an air spray canister (just compressed air), open your Xbox's game tray, take the disc out, then spray the air along the tray, moving side to side inside the Xbox. You may want to spray into the vents, too, just to be sure.
This worked for me, and it was the only thing that worked for me. I had already tried hitting the console with the controller (gently), and doing the stuff Microsoft recommends etc.
If that doesn't work, you could try gently knocking the top of the Xbox with your conroller, when you put the disc in, as I've heard that works for some people.
Another thing that works for some people is taking the disc out, closing the tray, then when it goes to Open Tray, open the tray, put the disc back in and then closing the tray again.
Jun 17, 2010 | Microsoft Xbox 360 Console
Put disc in xbox 360, said reading then open tray. wont play no discs
@paulhull58 when the disc tray closes push down firmly on the top of your xbox where the tray is. if not clean your disc.
Apr 04, 2010 | Microsoft Xbox 360 Console
Disc tray won't close
Whenever you need help with your Xbox or Xbox 360 accessories, allways check out Xbox Customer Support
The answer to your question is quite long, so here's a link.
Xbox 360 disc tray help
Hope this helps
May 20, 2009 | Microsoft Xbox 360 Console
Disc tray on Insignia BRDVD player will not open. Any help would be appreciated. Press the open/close button and display says either open or close. The tray does not eject though.
the disc is probably stuck out of the tray and stopping it from opening. unplug, and you should be able to pry open the front case and pull the tray out.
Apr 13, 2009 | Panasonic SC-HT730 System
Disc tray problems
Redeem your warranty, this issue happens with the tray is going bad, first this small problem next reading problems
May 19, 2008 | Microsoft Xbox 360 Console
Tray Opens and Closes Repeatedly After Disc Jam
check to see if tray is out of alignmnet ..also check to see if 5 or 7 pin flat ribbon cable form servo drive board to tray got dislodged from connector or is bent,cut etc...
Dec 03, 2007 | Sony DVP-NC650V Multi-disc DVD Player
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Televison & Video Logo
321 people viewed this question
Top Lite On Televison & Video Experts
Jaime Hernandez
jason
Are you a Lite On Televison and Video Expert? Answer questions, earn points and help others
