Question about Philips Televison & Video
Buttons & remote not working - Philips Televison & Video
  • lofty2304 Jul 21, 2008
    Philips DVDR3570H buttons not working or R/C will not operate the DVD player
  • 2,334 Answers
Can you provide more info on brand and model of amp you have?
Posted on Jul 21, 2008
I have a remote control model # R520T, It was working in the past and now will not work at all. What do I need to do ? Sears told me that they no longer have this unit for sale.
That fan is most likely made by emerson. The model number you supplied is only for the remote and it is hard to tell from that number, if you could get the whole model number off the fan it would be better. With that in mind you can browse here: http://www.ebay.com/sch/items/?_nkw=universal+ceiling+fan+remote+control&_sacat=&_ex_kw=&_mPrRngCbx=1&_udlo=&_udhi=&_sop=12&_fpos=&_fspt=1&_sadis=&LH_CAds=&rmvSB=true
to see if one looks similar to yours. The real issue if you want to try and repair it lies in the rubber buttons that you press to operate the fan, Those buttons have carbon impregnated rubber and they oxidize over time and don't make a good connection. Take out the battery and look for screws that hold the unit together, remove the screws and separate the housing. Take the electronic board out and clean the contact side that faces the buttons with alcohol and q-tips. Do the same to the bottom of the buttons. Reassemble it and test it.
Aug 12, 2016 | Dryers
What's the difference between sony rm-yd028 or rm-yd065?
To most Sony remote controls, P+ / P_ & Vol+ & Vol -- ; buttons will work, except for other buttons will work. The difference between the Sony remote controls you mentioned here too will differ to these function. http://electronicshelponline.blogspot.com/
Oct 19, 2014 | Televison & Video
The sat button on my remote is rapidly blinking, and now most of the other buttons will not work.
When the SAT button blinks repeatedly, or the buttons do a dance (Sat & DVD, TV & AUX, repeat) it means you need new batteries. Replace all four AAA batteries, ensure they are all four aligned the same way, and then hit SAT. Your remote should return to its normal function. If you leave the batteries out for too long, the remote will forget how to operate the TV and receiver, so be sure to have all four new batteries ready before you remove the old ones.
Oct 17, 2014 | DISH Network Televison & Video
The power on/off button on the remote control works but the channel & volume buttons no longer work
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 15, 2014 | Televison & Video
The volume buttons on my remote for an amp won't work.
try a piece of alum. foil next time before you cut the buttons out---may still work with clear tape over it.
Nov 06, 2012 | Televison & Video
Some buttons on my remote for my yamaha htr 5750 amp don't work. It's the original and was given to me. The volume and power buttons don't work or make the red lite flash; however the other...
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remote", check the 'include description' box. Usually cheaper than the vendors.
Sep 10, 2011 | Yamaha HTR-5750 Receiver
Select & skip forward buttons no longer work on the #2 UHF remote
THis solution depends on your ability to do it yourself.
If you are brave enough you can disassemble your remote and dust the black blisterpads with graphite powder being careful to blow off any residue before reattaching. This will add some life to that old remote, but eventually all things must be replaced. Graphite powder can usually be found at most office supply houses and some Schools. It is usually used to lubricate slide rules.
Mar 07, 2010 | Televison & Video
TV won't take remote control commands
I have the same issue. Obvious thing is to install new batteries. I assume you have done this already. Have you tried using the buttons on the bottom of the monitor to scroll through the main menu using the volume buttons to option 3, and scroll down to IR remote to see if it is selected ON. If it is OFF, select ON with the bottom LEFT or RIGHT buttons.If your remote still does not work, you can try to work it by connecting a 1/8" stereo mini-plug cable into the front end of the remote and the other end to the monitor remote control jack(second from bottom on back panel). Check the IR Remote settings this way. If it still does not work then you have the exact same problem I have... IR and Wired remote inoperative. I am still hoping for a solution but I am afraid there is either a stuck bit in the IR remote circuit or a bad board/chip. Anyone have a solution to this??
OPTION3
KEY LOCK OFF←→ON
IR REMOTE OFF←→ON
LOOP OUT OFF←→ON
ID NUMBER ALL←→1←…→256
Nov 08, 2009 | Pioneer PureVision PDP-424MV 42 in. Plasma...
Some buttons on my DISH TV Remote don't work!
i used to have a nintendo that did that so i'd take an eraser to the back of the buttons and connections on the circuit board and put it back together problem solved:)
Jun 21, 2009 | Sony RM-V310 Remote Control
Marantz Remote control model RC-18SR
Does the SOURCE ON\OFF button still work? If so, you can still use the remote to turn the receiver on and off by first pressing the AMP button (so that the remote window says AMP) and then pressing the SOURCE ON\OFF button.
Dec 23, 2007 | Audio Players & Recorders
Televison & Video Logo
23 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
