Question about Samsung CLP 300 Laser Printer
Hi clp cyan not printing properly
Hiya, i own a clp300, the blue was fading when i printed followed by changing the cyan printer toner becuase the printer was telling me it was low. when i changed the toner with a brand new one the same thing is happenin. the printer is only a few months old ...
i opened the old toner and out poured lots and lots of toner ink ....
do i need to send it back? i think ive lost the receipt...
If its still under warranty ull be fine
Posted on Jul 26, 2008
Same problem
Samsung CLP 315 invalid toner message
the best thing to do is buy the original toner. how ever if u really can't then try changing the blue colored one
Jul 29, 2017 | Samsung CLP-315 Laser Printer
Instead of Bule print DC12 prints Violet
Hi there! The blue color is becoming violet because the Cyan and the Magenta toners are not getting mixed in the proper 100:100 ratio (100% Magenta and 100% Cyan make CMYK Blue). Since the print is violet, the culprit is the Cyan toner. Now, first, get the Cyan Developer Assy checked if there is enough developer in it. If no, get it refilled by a proper tech and manually mix about 50 grams of the Cyan Toner with the developer. Also get the tech to check the trimmer gap on the Developer Assy with a metering gauge. If yes, next check the Cyan dispenser motor located on the backside of the Toner Housing Assy. It is probably broken and not dispensing any toner to the Cyan Developer Assy . Additionally, check for the Cyan Dispenser Auger blockage or jam. It is located under the Cyan Toner Cartridge in the Toner Housing Assy and also check the auger under the Cyan Developer Assy. After sorting these out, you should get proper CMYK blue from the 10th or 12th page once you resume printing.Let me know. Regards
May 26, 2011 | Xerox DocuColor 12 Color Copier
THE QUALITY OF PRINT FROM MY SAMSUNG CLP300 HAS BECOME POOR, WITH SOME BLACK INK FADED
If the print is faded down the length of the page, then the problem lies within the imaging unit. This is a very commn problem with this printer. The developer blades get blocked by a coating of toner, which after many prints, cause a noticable fade in the image. This can be fixed by replacing the imaging unit or the blades can be cleaned. I have detail instruction in my tips section. It can be done quite easily if you are handy, and you could save yourself some money by not buying a new imaging unit.
Apr 22, 2010 | Samsung CLP 300 Laser Printer
How to reset printer counter samsung CLP300
There are two major counters in this samsung CLP300 color laser printer.
I will give you the answers for both.
The standard one is the page printed counter.
You can not change that
The only way is to change the system board or get an used printer
(AS LOW AS $80 now!) and swap it.
The other set of counters are the toner counters.
eBay seller tpstock6898s.gifhas them
Set of Samsung CLP 300/CLX 3160FN reset Chips
eBay Item number: 260468470362
http://cgi.ebay.com/Set-of-Samsung-CLP-300-CLX-3160FN-reset-Chips_W0QQitemZ260468470362QQcmdZViewItemQQptZBI_Toner?hash=item3ca521725a&_trksid=p3286.c0.m14#ht_790wt_1165
You can pick up the whole 4 chips set to reset the data to the printer for under $10.
Please post more information on what you like to reset.
I will follow up on this post.
Aug 29, 2009 | Samsung CLP-300N Laser Printer
Faded black print.
may have gotten a bad cartridge ! try another one !!
Jul 21, 2009 | Samsung CLP 300 Laser Printer
Black printing faded although toner not low
The black developer is defect, you have to call the service to solve this problem. and install FW Update V1.29.12.35
May 27, 2009 | Samsung CLP 300 Laser Printer
metering blade is gunked up. You need to dissasemble part of the imaging unit to fix the problem. Clean it. put it back together and BINGO! Like new. Do this before throwing money into buying a new imaging unit.. You can thank me when this works
May 20, 2009 | Samsung CLP 300 Laser Printer
Pring quality on Samsung CLP-300 colour laser
If you the image is faded and your toner supply is good, the problem is the developer blades in the imaging unit. During the normal use of the printer, there is a buildup of toner that sticks on the developer blade. The developer blade meters the amount of toner that gets to the drum that ultimately makes it to the paper. As the toner buildup increases on the blade, less and less toner that gets to the drum cause the image to fade.
To fix this problem you will need to disassemble the imaging unit and clean the blades or buy a new imaging unit. I have clean my blades and I don't have 20000 images it is about 7000 and I have a document to show you if you are handy.
Dec 10, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
151 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
