Epson t 13 are problem cannot accept the printer ( new Cartridge) problem 1) cyan col. charge is taken problem 2) Yellow col. charge is taken problem 3) Magenta col. charge is taken problem 4)But black col. charge is cont charge ...replace cartridge any 3 color accept printer but 4color attach ? than replace what the problem
Printer manufacturers do not want folks to use cartridges that have been refilled and they deliberately design their printers to not work with refills. If you get a generic refill you have to make sure that they have taken measures to counteract what Epson has programmed into their printers.
Chalk up the experience to GREED - they want you to use their grossly over priced inks - that is where they make their money! Check in Google for work a rounds this nonsense.
You can't print in black only mode because printer need all cartridges not empty to initialized and working.Don't try to refill this cartridges, it's have a chip and you need to reset it too.Just look in your are for non OEM ink cartridges.Thea are 2-3 times cheaper.
Check for the tape that wraps all the way around the cartridge bottom it usually has a red line on one end like a tab DONOT REMOVE THE ONE THAT LOOKS LIKE WIRES ON IT.... is it still there if so remove it.............MAKE SURE THE CARTRIDGE IS SEATED PROPERLY IT DOESNT TAKE ALOT OF STRENGTH TO INSTALL.....
What model printer do you have and can you list the print cartridge?
Also have you selected on the onboard printer menu that you have inserted a new cartridge?
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
