Question about Zebra TLP 2824 Printer
Zebra 2844 I am trying to print from a word document using the Zebra Printer- I am making over 1000 labels but for some reason it will not print. Any solutions?
  • puttym Aug 27, 2008
    I have a similar problem using a Zebra 170xiiiplus printer. Tech rep said I could print Word document by selecting File/Print and selecting the Zebra printer. The data light flashes, the label advances, but nothing is printed on the label. Please help.
    Scholar:
  • 62 Answers
Do NOT use the Zdesigner driver. Ensure that you select the Zebra printer driver or ZUD driver, which can be downloaded from zebra website. Go into the driver settings and select the correct label size. Print a windows test page to verify correct operation, Once the correct windows driver is installed you can then open any windows application, paint, word, excel...etc.. and print to your zebra printer. Do NOT use the Zdesigner driver.
Posted on Jul 20, 2009
  • Zebra Master
  • 2,794 Answers
There is specific coding you need to use to get it to work. Word documents add special characters to the batch files causing them not to printer properly.
You could try a merge to printer opertion in word and see if that will work. Make sure you to turn the printer on and off before attempting it to reset the control codes.
Posted on Jul 21, 2008
TLP2844 won't print
Hi David,
Default the printer so you have a green light.
Print a configuration label so you have the printer's settings.
Check the document you are trying to print.
If your "normal document" is using PCL, it won't print because you aren't speaking the printer's language.
Make sure you are using a Zebra driver and that the label/media settings match your printer. Look at your direct thermal/thermal transfer setting and your media length setting -- especially continuous vs. non-continuous.
Sep 21, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2844-Z Test page print within Win XP
This printer requires special software to print labels with. It uses a unique PCL language to work with. Thats why when you use these printers with Fedex or UPS software, it typically downloads forms first before working.
Zebra used to see a label designer program to work with it. You might want to check with them to see if they still carry it.
Jul 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
ZEBRA TLP 2844
plz try to use in another port(if available) or try with another cable
Jun 30, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2844 print blank page
Possibly because the button does not work, causing the advance of the labels. Replace it.
May 13, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 2824 Printer Logo
879 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
