Question about Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 problems with vertical alignment
Hello We have been using our Xerox Phaser 8400B without problems for a while (3 years now)  but for the last year, we are having problem with vertical miss-alignment  of the 4 colors (including black). We change the roller for higher print count and it was working OK for a while then again, the color start shifting vertically  making looks like out of focus. The printing material looks like an EKG machine  on a tight spread.  Can anybody help us? Thanks
  • mmijp Jul 21, 2008
    Here is a sample of the problem:
Most likely the drum endbell has come loose. You see, the motor drives the endbell which is connected to the drum. When the endbell gets lose (which can happen) the drum (and thus the drum surface) get our of step. It causes artifacts just like this. It would be really hard for this to be anything but the endbell slipping out of the drum. You may be able to see this if you look closely or listen. It might make a scratching sound. anyway, just my guess.
Posted on Mar 04, 2012
  • 2,072 Answers
That can be one of two things.
1. There is a drum encoder on the end of the drum motor.that picks up silicon lubricant from the maintenance kit roller. Normally removing it and cleaning it will resolve the issue, sometimes it needs replaced.
2. There is a print head block that can become dirty and not allow the print head to get into the proper printing position, but that most likely would cause an 07,10.043 code and shut down. I really suspect a dirty/contaminated encoder.
The encoder is on the right side of the machine looking from the front, once you locate the drum shaft you will see it. Sort of flush it out with alcohol and allow it to dry, put it back in and you should resolve your problem. If not let me know.
If you need to order one the part number with diagram is on, under downloads and documentation, there is an online parts list for that machine.
Posted on Jul 22, 2008
Xerox Phaser 8400 Front Cover Open
Yes, there is an OPEN/CLOSE sensor that is sending wrong "status" information to the printer.
Jun 01, 2010 | Xerox Phaser 8400 Laser Printer
Error message Xerox Phaser 8400
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Iam getting an error code on my xerox phaser 8400 ... code # 08,055.44:92360
. Check for spilled ink and ink overflow from printhead reservoirs. If reservoirs have overflowed or a large amount of ink is present in bottom of machine, the printer has most likely been tilted, tipped or moved while hot and this may not be covered under normal warranty or service agreement. Contact Customer and Technical Support for additional troubleshooting assistance. 3. Check printhead wiper, wiper belts and drive gears for damage. 4. Check the wiper alignment and physically align wiper as outlined in Section 6 of Service Manual, Wiper Alignment Procedure. Run the Wiper Alignment test. Reference Section 3 of Service Manual 8,0XX.xx Errors - Wiper/Media Drive Faults. 5. Run the Head Maintenance Clutch test.
Mar 02, 2010 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 gets no power
I have been hesitating on answering this because people hang me out to dry on phaser printers when I give them good info. But here goes.
What you can try is go to the back of the machine, whre eh on off switch is located. there are 2 larger thumb screws you twist to align with the back frame. That holds the main board in place, Losten them, remove the main board, reseat the RAM memory into its slots, re insert the main board and try turning it on. If that doesn't work the most likely problem, ( 90 % likely) is the electronics module. And I am sure you did not pay as much for the machine as an electronics module would cost, Generally they are over $1000. Best price.
Jan 21, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400/8500/8560 maintenance kit
No, it will not work because the chip (CRUM) is not compatable.
Jan 13, 2009 | Xerox Phaser 8400 Laser Printer
Phaser 8400B PS
Thats a piece of paper being detected when the machine is turned on.
There is a small piece of paper ripped inside the machine, or a paper path sensor has popped out of positioin.
Sep 02, 2008 | Xerox Phaser 8400 Laser Printer
I have a phaser 8400 banding problem. Actually reverse banding. It is ligher ink vertically along left margin and an inch from right margin. Is this a drum problem? It notes I am low on ink and have only...
nope its not a drum problem, That drum never goes bad. You are having a problem with some blocked jets in the print head.
You can scroll through your menu to troubleshooting and there are cleaning modes to eliminate light stripes and to eliminate smears.
Run the eliminate light stripes maybe 2 or 3 times. If that doesn't work, then try the jet substitution mode.
That is better described at, click support, then enter phaser 8400 in the search box, click support again and then enter
"jet" in that search and follow the directions.
If those do not work then your print head is most likely bad. Thats more likely if you have used non xerox ink sticks.Being low on ink should only give you a message that its low.
Aug 25, 2008 | Xerox Phaser 8400 Laser Printer
1, The NVRam memory is corrupted.
2, A jet heater is not working
3. the electronics module is bad.
Parts possibly bad are the NVM, the Print Head or the Electronics module.
Hard without a manual to determine, all are expensive.
May 30, 2008 | Xerox Phaser 8400 Laser Printer
Xerox phaser 8400
The first obvious question is, "Does it have blue ink/wax?" Is it displaying any errors? Have you tried the Xerox support site? They have a fantastic utility that can connect to your printer and diagnose many problems. Here's the URL for the utility: They also have a wealth of information in their knowledge base. Here's the URL for the support page for the Phaser 8400: Did anything happen before the blue quit printing? Have you tried running a cleaning cycle?
Aug 21, 2007 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 Laser Printer Logo
238 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
