Question about RCA F36674ET 36" TV
RCA 36 inch ---channels keep changing
Yikes...everything was fine and suddenly the channels began to change from one to another by themselves....at first I thought I had watched too many scifi movies ....I tied turning off but it just keeps on flipping....
Any ideas???
Thanks so much. Andrea
    President:
  • 3,113 Answers
Mine did this and I took the back off of it to remove the button panel on top of the tv. It un- snaps from the inside and pulls straight out. My channel down button was messed up but it lookd fine. It has three prongs on one side of it and two on the other. I clipped the two prong side of the switch and put it back together. Works fine now with remote. Be careful as the set picture tube holds high voltage for a long time when unpluged. Unplug overnight and then work on it.
Posted on Mar 06, 2010
Rca tv truflat 20f511t
Bring up the menu for the tv with the remote and try to find something to the effect of resetting everything to factory default settings. If this does not rectify the problem, it probably is not worth taking in to get fixed as this can be very expensive and the tv is older anyway.
Dec 28, 2013 | Televison & Video
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
After a power outage my rca 36 inch pip changes channels
the manual buttons on ur tv set seems to be stuck, take a look for any damage or corrosion or for anything
May 10, 2009 | Televison & Video
Radio tuner stopped working
replace Bad Circuit Dsp Pcb the rca part number is #265973
Jan 13, 2009 | RCA RTD258 System
Channel keeps changing
it seems to be continusly scanning channels and never ends
Jun 28, 2008 | RCA F32649 32" TV
TV turns on & off by itself. Channels also change by themselves.
Make sure your remote is totally away from the set.
Make sure the buttons on the set are not sticky
If both of those are ok, it's your E-Prom in the set. RCA's are notorious for this, not a major repair, maybe $75-100. The 8 leg e-rom is only about $6.00
Apr 11, 2008 | RCA F36668 36" TV
Suddenly, can't get all the tv channels!
Try resoldering where the tuner mounts. Rca has had some problems with solder connections
Oct 16, 2007 | RCA F36649 36" TV
RCA F36685 No audio on cable channels
1)Try hard reset = unplug AC cord overnight
2)Further audio circuit work is shop repair by skilled,senior
RCA products technician........................................T.
Sep 03, 2007 | RCA F36685 36" TV
Televison & Video Logo
118 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
