Question about JVC Computers & Internet
Trouble transferring video to DVD
I have video's that I am turning into DVDs. I have been using DVD-R discs and have suddenly found that each time I start the recording processit will stop about thirty to forty seconds into the recording. I once managed to make it into a minutes worth of recording. Once attempting to do the dubb, the DVD is ruined. The machine says it is a disc error, even though the disk was fine before the attempted transfer. The JVC website does not seem to have any information abou this problem.
    Problem Solver:
  • 5 Answers
Hi...
have you uninstall and reinstall your burnning software? change your DVD-R brand, slow down your burnning speed, update your mainboard chipset
may help
Posted on Jul 23, 2008
Toshiba 22lv505 TV/DVD Region Code Error
maybe the spindle motor is turning defect causing not to spin the disc naturally,its time to have to check that to the Toshiba service center
Jun 20, 2010 | Toshiba 22LV505 22 in. LCD TV
I have recorded from Vhs tape to a DVD-R. When I insert DVD-R to play in Emerson EWD2202 it tells me that playback feature may not be available on this disc. Emerson's manual says it will play DVD-R....
Without sounding too pretentious, I would first advise you to use a QUALITY disc for exactly this reason! Don't be afraid to spend a little more on some TDK or Hitachi/Maxell DVDs! **** DVDs will fail as much as 25-40% of the time, making them no bargain at all!!
That being said, I would also inquire as to exactly what methods/products were used in the transfer process. There are several different ways of writing data to the disc (DAO, TAO, etc...), as well as many different video formats (did you select "Make a video CD" from your application? This will only work in digital video disc players, NOT DVD players!). Only a few (if that) will typically work on any given player.
On that note, my advice would first be to copy the data from the disc back onto your PC if possible (if it isn't still there already), or even from the VHS tape again, and take a look at the file name, particularly the extension, of the copied video file(s). If the extension is not .mpg or .mpeg, then it is NOT in DVD format, and converting to the appropriate format would be a necessary part of your transfer process. Also, make sure you are creating a DVD, not a video disc! They are different! Rewrite the data to the disc in the appropriate format on good quality media using the same process as before and you should be good to go!
I hope this helps! If not, please comment with any additional information and I will respond ASAP and we will get things figured out for you. Thanks for your questions!
Jan 08, 2009 | Emerson EWD2202 DVD Player/VCR
Cannot write to disc
Is this the unit?
It says the Everio only uses DVD-R or DVD-RW DVDs. Is that the type of DVDs you are using?
Aug 16, 2008 | JVC Everio GZ-MG130 Camcorder
How do I transfer my video from the DVD to my computer?
this is how i do it:
I use nero vision express 3 to edit my dvds. first just finalize the disc on the camcorder (if it lets you! i;m having trouble with mine on a particular disc), hook it up to your computer, use nero vision express 3 to import the disc (it helpfully converts the file format into mpg for you) and there you go!
im sure there are plenty of other ways to do it too.
Mar 16, 2008 | Panasonic VDR-D100 DVD Camcorder
DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Sep 18, 2007 | GoVideo Go Video VR3840 DVD Recorder/VCR
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Transfer from DIgital camera to Share station not working
Had the same problem.No matter what disc I used it seemed to fail.Found a Verbatin DVD-RW 4X and works perfect.Seems to be a disc speed problem.Only use 4x.Hope this works....
Aug 28, 2007 | JVC Everio Share Station DVD Burner Burner
Trouble transferring video onto PC
First thing to try is updating the picture package software(assuming you have windows XP); http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRDVD403&UpdateType=Everything&SelectOS=7 Probably worth uninstalling and reinstalling the program before applying the update. The update doesn't claim to fix your issue, but try it anyway, there are sometimes additional parts to these updates. Here is the link for the user manual if you need it; http://esupport.sony.com/US/perl/model-documents.pl?mdl=DCRDVD403®ion_id=1 Check page 100 - USB speed setting - see if that makes a difference. Check page 86, it has contact links for pixela, who support the software. If you record a movie, then finalise the disc before trying to transfer the video, this should stop any recording over information without formatting the disc first. then put the disk into your pc dvd drive instead of using the cable link. You should then be able to view the movies using most media player programs. Try a dvd on which there are only movie files, no still images - see if you get the same problem. Hope this helps, please ask again if you still have a problem :)
Jul 13, 2007 | Sony Handycam DCR-DVD403 DVD Camcorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Computers & Internet Logo
74 people viewed this question
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Tre Elkins
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
