Why won't my ac cool - Heating & Cooling
  • James Helmer
    James Helmer May 11, 2010
    Just stating that the air conditioner does not cool is a very open ended question. We need more information like is the compressor running?, is the blower running?,
  • 143 Answers
It's either the wrong size or it's broken.
Posted on Jul 22, 2008
My engine light is on, my AC won't blow any cool
Need more information to assist.
Check your coolant level.
Sep 12, 2013 | Cars & Trucks
Fan won't blow on ac, but works on furnace
The fans heat speed is low speed and the cool speed is high speed. High speed is controlled by the fan relay normally open switch, the low speed is controlled by the temperature delay or time delay.
see diagram
Jun 05, 2013 | Coleman Home Electric Furnace Eb15b/Eb15d
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
2003 BMW 325i a/c compressor won't turn on
either low gas or a the compressor soloniod /clutch packed up their the two most common causes
Dec 19, 2012 | 2003 BMW 325
Whirlpool matermind window AC shows error code F2 when power on and won't cool. Sometimes it starts up perfectly fine.
F2 ---for me its a sensor problem had it done thanks katsaras
Unit -- Whirpool AC Model no. Wasr18k20 1.5 ton split AC
Jul 25, 2012 | Heating & Cooling
Cooling fans won,t come on
1 fan is for cooling the motor and the other fan comes on when the ac is turned on or its very warm outside it 2 stage
Nov 08, 2017 | Cars & Trucks
Dometic roof ac will not cycle
check wiring and dip switches make sure fan on auto
Jun 14, 2012 | Dometic Rooftop RV Air Conditioner
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
How did you know when the cooling fans are not working
You may have one conventional belt-driven fan with a thermal clutch and the other electric or, both could be electric on your car.
The cooling fan that operates during non-AC operation (just a running engine) if electric, will be controlled by a thermal switch in the lower radiator tank and may not turn on at all unless the engine is warmed up. The belt-driven fan should be turning at some speed all the time if the engine is running and at much higher speed with a hot engine.
The fan that cools mostly when the AC is operating won't run under normal operation but may turn on in hot weather (or when the engine is under heavier loads) even without the AC operating.
Checking them would require having a warmed-up engine and the AC turned on. Both fans regardless of type should be turning then.
Jun 03, 2011 | 2000 Mercury Cougar
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
