Question about Canon imageCLASS D860 All-In-One Laser Printer
Lines on copies
My copies all are having 5 lines added on the left side (3 together) and a space and then two lines toward the middle.
I am having a similar problem, there's dark lines on the left side of my copies. It doesn't matter if it's on the glass or not. I also think that the lines are getting bigger and darker over time.
Posted on Aug 19, 2008
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Is it happening whether you put it on the glass or not, or only in the feeder?
Posted on Jul 21, 2008
I bought a Jaguar s type from Japan and the dashboard writes in Japanese,how do I change it to English,please help
Push <menu> button (2nd button on the right side of the screen).
On the screen you will get 5 tabs in 3 lines (2, 1, 2).
Push <system setup> - the one in the middle (2nd line).
Now you'll have 3 tabs in 3 lines.
Push <user settings> - the 2nd tab.
Now you'll have 5 tabs in 3 lines (3, 1, 2).
Push <language> - the long tab on the 2nd line.
And you should be able to choose a different language.
Nov 17, 2014 | Jaguar S-Type Cars & Trucks
When I copy papers on my Canon imageRunner 2800 there are 2black lines in the middle of the copied paper. How do i solve this problem?
Hello mike,
You may have a fairly easy problem to fix, and that's good thing ! If the lines only appear when you use the document feeder then we can handle this. Please place a document on the platen glass and make a copy. If the copy looks good then we need to clean your "scan" glass. The scan glass is the small glass located to the left of the large platen glass. It's about 3/4" by 14",and will only cause problems when you use the automatic doc feeder.If it gets dirty then thin lines will show up. If indeed this is the problem then I have a test u can use that will help you Take a plain piece of paper. Mentally divide it into 4 squares and then simply write the numbers 1,2,3,4 on each quadrant. At the top edge of your newly formed test document place an arrow pointing away from the body of the paper, and it needs to point "UP".. Now draw an arrow on the test document that points to the left "lead " edge. Put your newly constructed test target in the document feeder and make a copy of it. Now, you KNOW how you placed the test document, so lets look at the copy. If you have lines only thru the document feeder, then look at the copy you made and notice where the lines are. Ok, now you know where the lines show up on the copy, so lets take your "test" document and compare them side by side.Once you have made this comparison, and can see where the lines show up, take the ORIGINAL test document and place it IMAGE UP (1,2,3,4) on the glass. This will point out exactly where the dirt is. By looking at the copy that has lines, and where they show up on the page, you can use the test page that is laying face up on the glass and compare the 2. BOOM !! You can look towards the small scan glass and find the dirt that is causing the lines. With your copier, IF you place a document on the glass then the scanner moves to "scan" the document. But if you use the document feeder, the scanner stays in one spot and the motion of the document moving ACROSS the scanner and is scanned like a bar code. If there is dirt on the scan glass then a line occurs instead of a "blob" as you would see if you used the platen glass.I hope this all makes sense (I tend to ramble) and I hope it helps you. You of course could have far more complex problems. But your description of the problem sounded like my remedy/idea might be just what you need. Take care and good luck. if I helped you please let "fixya" know. SPINAL
Apr 02, 2011 | Canon Office Equipment & Supplies
3 thin black lines on copy
Do the black lines show up when you use the adf or if you make a copy from the copyboard glass. If the lines only show with the adf > there is a small **** of glass on the left side of the copy board glass > I would clean the slip glass with windex or a damp cloth..... Good Luck
Jun 08, 2010 | Canon imageRUNNER iR C2880 Color Copier
Black stripes on copies using a Canon D1120
Do you use the Doc. feeder? Try to make a copy off the copy board glass. Is the line there? Now make a copy with the adf. Is the line there? If so, you need to clean the small glass under the doc feeder. It looks like a glass ****, about a 1/2 inch wide. Clean it with windex and that should solve your line problem...
May 11, 2010 | Canon CLC 1140 Copier
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Horizontal Lines Only being printed?
Sounds like your printer nozzle could use some maintenance.
Dec 16, 2008 | Epson RX620 All-In-One InkJet Photo...
Spaces in printed lines
then the problem is in cartridge replace them asap, no other way around it,
Sep 04, 2008 | Dell 922 All-In-One InkJet Printer
Horizontal lines
if the signal on your antenna (cable) is ok(make sure of it),the tv set has a syncronisation problem.please contact the nearest tv repair shop.
Jun 03, 2008 | JVC AV-27230 27" TV
Vertical lines across the screen
Change ballast and lamp at same time. Ballast #75006507 lamp #23311153
Sep 11, 2007 | Toshiba 46HM95 46" HDTV
Canon imageCLASS D860 All-In-One Laser Printer Logo
old marine
old marine
