Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
Cannot see Screen contents
When I turn the monitor one I can see the screen contents for about 1 second before it goes black. If I turn the monitor off and back on, I can again see the contents for about one second.
  • 4 more comments
  • threedears Jul 22, 2008
    I have the same problem with a Westinghouse LCM 20v5 flat panel LCD monitor. Initially after hibernation, the screen would show for 1-second, then go black. I kept the screen on during hibernation and that worked for a few days, now I cannot get the monitor to recover, even after re-boot.
  • piersanti Jul 27, 2008
    same problem - stays on for 1 second, then goes black
  • max2000 Jul 27, 2008
    Same problem with the L2046NV. Stays bright for a second and then goes dark.
  • latchdogg79 Dec 18, 2008
    if you keep pressing the power button on and off eventually it stays on until it is turned off or hibernates again
  • alfaquad12 Dec 25, 2008
    i also have same problem. Turning off and back on several times eventually got it to "stick" on .... this worked for a couple fo days.... now the green led light comes on... but the screen remains black.
  • l_tharp Mar 22, 2009
    Shortley after turning the tv on the screen goes black
  • 13 Answers
I fixed it! It's the power supply board.
The Westinghouse LCM 22w2 has bad capacitors on the yellow power supply board. This is a common problem plaguing motherboards and LCD flatpanels that use capacitors from Taiwan. If you know how to solder, or know somebody that can, it's actually a pretty easy fix. Take out the yellow circuit board on the inside, write down the specifications for each of the capacitors (the cylindrical things) go to the electronics supply store and get the replacement capacitors. You can go over the voltage specification (not under), but keep the capacitance value matching. Replace one at a time. Go to for advice, tutorials and training on doing this. *You really should replace all the capacitors*, but the very large one next to the power plug I did leave on the board because I couldn't find a match. To my delight, it was working as new!
I saved a ton of money fixing this, it's definitely worth learning how to solder to do this. for professional hosting solutions
Posted on Apr 09, 2009
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
Black screen
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Used as second monitor suddenly stared to go dark
If the screen is lighting up for a fraction of a second when you turn on & then goes dark, this indicates a fault either with the backlights on the screen or the inverter part of the monitor. You can check the backlights if you have access to a backlight tester, you need to remove the rear cover & connect the backlight cables into the tester, if this checks ok then look for a problem on the inverter board, checking the capacitors for any signs of distress.
Aug 11, 2009 | LG W1934S-BN 19" Monitor
Monitor isn't working...shows desktop screen for a second then goes black.
reinstall windows ur screen resolution is not accepted by monitor
Apr 26, 2009 | Computers & Internet
Screen goes black
It could be a bad backlight bulb.
Sep 08, 2008 | HP vs15 15"LCD Flat Panel Monitor
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Black screen
How old is the computer? Make sure that the power light comes onto the monitor when you plug it in, should be orange and then turn green when video card syncs with it when PC is turned on. If you are getting black screen when PC is powered on:
1. Bad video card
2. Bad video cable
3. Bad monitor
1Solution: Try using a different monitor attached to this same PC and see if it works. If it does, then its the monitor, its cable, or its power supply. If it doesn't work, then its the video card or the video cable coming from monitor.
Nov 24, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen turns black
problem with the inverter chek it
Mar 18, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
323 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
