Question about Linksys Wireless-G WRT54G Router
Linksys Issue im looking to find a device i can plug into my USB on my xbox360 that can detect my linksys i have a wire ethernet cable but it wouldnt reach from my room to downstairs
  • 19,396 Answers
Dell XP 200 Dimension ethernet port
Hello.
I'd suggest testing with another computer and the same Ethernet cable to your modem to see if the results are the same and to narrow down which component is the problem.
Was it always slow with this setup or did something change.
Is the Linksys adapter connected via USB ? That would be slower than an internal adapter.
Try updating the Linksys adapter software - Device Manager - rightclick - update driver.
Hope these suggestions help.
Dec 23, 2009 | Dell XPS 200 PC Desktop
XBOX360 Wireless Adaptor does not see my already set-up wireless network. I have Verizon FIOS as my ISP and a Linksys Wireless-G WRT54G Router. I can plug an Ethernet cord into one of the ports on the...
Please follow the steps below to setup your Xbox with your Linksys Router:
  1. With your Xbox powered down, take an Ethernet cable and plug it into a numbered port on the router, and plug the other end into the Xbox.
  2. After you have your Xbox connected to the router, start up the Xbox without a CD in the tray.
  3. After you start the unit, you should arrive at the “Xbox Dashboard”. Select the Xbox Live option and press the “a” button on the controller.
  4. After “Xbox Live” loads select the Network Setup and press the “a” button your controller.
  5. On the “IP Address” settings, you can choose “Automatic” or “Manual”, make sure it’s Automatic.
  6. Select the Connect option and press the “a” button on the controller.
After you use the “Connect” option, the Xbox will detect the network cable, and will ask you if you want to connect to Xbox Live.
Aug 17, 2009 | Linksys Wireless-G WRT54G Router
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Broken Ethernet Port
You say "your Ethernet Port" (= LAN port)
If unavailable try using any USB to rj45 adapter and you can use any USP port.
Check this device:Linksys - USB200M - Compact USB 2.0 10/100 Network Adapter (20 $?) or similar
Dec 28, 2008 | Linksys Wireless-G Broadband Router
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
Dell 4700 Computer Integrated NIC Problem
Check for the pins inside the integrated NIC to check if the pins are bent / disfigured. Does not look like the additional card is making any different, looks more like a moving NIC cable is makin the difference.
Lemme know if this helped!
Dec 13, 2008 | Dell Ethernet Card Network Adapter
Toshiba WRC 1000 as a Wireless bridge
lets get the picture right. laptop connects to a wireless router. then u want to plug into laptop ethernet wan port of linksys ? you have to set router manual settings to gateway which is ip of toshiba... this is a fun topic. ive connected xbox360 to laptop this way.. never tried router. "fun times ahead!"
Oct 10, 2008 | Toshiba WRC 1000 Wireless...
The lights are on but the linksys is not working
Certainly if the conection directly from the router to the computer is not working then the wireless won't work. So that's where I'd start. Cable connections could be an issue. The connection without the router works I assume. Make sure you are connected correctly. You need ethernet cabling to the ethernet, networking connections to and from the internet device to the computer and into and out of the router. When you get the direct router connections working you can solve your wireless problems.
Sep 24, 2008 | Linksys Wireless-G WRT54G Router
Light on my RCA cable modem goes off when I connect a wireless router (Linksys WRT54G). It was workign fine for good 12 months until I was cleaning under the desk and zoom the light is out. When I connect...
It sounds like the ethernet port has actually gone bad on the router. The light turns on when the device detects a phyiscal connection to another device. Your modem does not detect a connection to the router... But it does the PC. So you know the issue is with the router.
Jan 01, 2008 | Linksys Wireless-G WRT54G Router
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
