Question about Pioneer DEH-1700 CD Player
Pioneer DEH 1700 not working now
I got a Pioneer DEH 1700 at a garage sale. Made in 2005.
I got it working after finding a wiring description on the web.
It was working fine..disc playing, clock working, radio working, all buttons doing their respective tasks.
I have some special cassette tapes that I need a tape player to hear so I wanted to install both a cd player and a tape player in the same vehicle.
I got a am,fm casette from a ford winstar. I had it working in a ford pickup.
Everything on it worked fine.
I unplugged the cd player and tape deck and moved on to figuring out how to cut out the removable plastic dash plate that I wanted to mount the 2 units in, one above the other. This meant I was picking up and putting down the cd unit many times, using it as a cutting pattern by tracing around it, test fitting it, standing it on it's side or end, removing and reinstalling the detachable faceplate, rubbing it against the tape player, test fitting it in the dash cavity, etc, I never dropped or banged it hard or exposed it to powered up wires.
Now all i get from it is a continuous clicking and the disk or radio won't play. No lights at all on the faceplate screen. I removed the top plate covering the cd player, undid the 4 screws holding the cd player into the whole unit and pulled it up and flipped it over being carefull not to break the wiring harness to the cd mechanizm.
Powered up, what is hapening is the small silver motor, via gears, is turning a 3" or so rod with a helical groove along it, kind of like a screw. It keeps going and won't stop. the grooved rod advances the reader head across the disk to, I guess, move the reader to the next track, (I don't know much about the internals of cd's)
anyway it has reached the end of its movement and the continuous clicking is produced by the spring loaded "nut" being pushed out of , then falling into, the helical groove/screw only to repeat this cycle endlessly.
Can anyone help me get this up and running again? or is it toast?
the red fuse in the back of the unit just above the wiring receptacle is ok.
with power to the unit, if I press the faceplate detach button and the right side of the faceplate pops out the motor/clicking stops.
I opened up the faceplate but everything inside looks ok to me.
to add insult I can't get the tape deck to work either....completely dead???
Help.
  • goldpro Oct 09, 2008
    Thanks for your input.
    turns out it was a fuse in the car's fuse panel that controlled the brake lights, etc.
    very wierd but I got it solved and both units work fine now.
    you were correct, they needed to be isolated from each other....perhaps that is what blew the fuse.
    I remember when I would touch the two units together there would be a small spark.
    I installed 2 speaker switches (each was double pole, double throw..I think) so the front or rear speakers can only play either the cd, or the tape but never both. This keeps them isolated.
    I can however have one set of speakers play the tape and the other pair spay the cd...but don't know when I'd ever use that....kids in the back?
    thanks again.
    Problem Solver:
  • 11 Answers
I'm guessing that you wired the 2 units together including the speakers? the 2 units may be of different potentials and can't be wired together like that...they would need diodes or a relay to isolate one from another.. first you need to see if you toasted each of these by separating the wiring and trying them separately...just a thought
Posted on Oct 09, 2008
Got a used pioneer deh 1700 can i ground to the back of the deck? no black wire
The chassis of the receiver normally is connected to its ground, it should work, but if want to look for the missing cable please follow the color sequence at the rear connector, the ground wire is the third starting from the yellow cable, the second should be the red one, for more details about your receiver please check the user manual at:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1700.PDF
Feb 19, 2011 | Pioneer DEH-1700 CD Player
What color is the remote wire on a pioneer supertuner deh 1700
CLICK HERE for the manual.
The wire is blue/white.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.04c3155.jpg
Oct 08, 2010 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer DEH-17 wiring diagram or pinout connection
the groung wire was torn out of my deh1700 pin connector where does it go back
Dec 10, 2009 | Pioneer DEH-1700 CD Player
Installation wiring diagram for pioneer deh 1700
here is the link for the installation manual and user manual:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-1700.Support
see the installation manual page 1 far right side for wiring diagram is listed as other manual
Cheers!
Nov 17, 2009 | Pioneer DEH-1700 CD Player
Pioneer DEH - 1700
The wires that you are looking for on the back of the radio is the yellow, red, and black. The yellow is for constant power, the red is for power only when the key is turned on, and the black is ground. You need all three in order for it to work.
Oct 23, 2009 | Pioneer DEH-1700 CD Player
Cannot find reset button
CLICK HERE for your owners manual in PDF format
Look for the reset button behind the faceplate.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question!!
May 13, 2009 | Pioneer DEH-1700 CD Player
Preset memory not working on pioneer DEH 1700 radio
You must connect the constant hot wire (or there is a fuse blown somewhere).... it should either be orange or yellow at the rear of the pioneer radio ... it should be connected to a wire that recieves power even when the key is off ... that wire will depend on the car itself ... if you used a connector to plug into the factory wires (a good idea) that connecter should have a yellow wire that would supply a constant "hot" for your pioneer, if it doesn't there should be a fuse blown in the car fuse box.
Apr 06, 2009 | Pioneer DEH-1700 CD Player
Deh-1700 goes dead on bumps
Loose or striped wire, pull the radio out and check your connections thoroughly.
Mar 19, 2009 | Pioneer DEH-1700 CD Player
Pioneer DEH-1700 CD Player Logo
277 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
