Question about Canon Office Equipment & Supplies
Mp210svst100ea24.exe Can,t get it to down load on windows 98
  • 2,039 Answers
That driver is for Windows 2000/XP/Vista. There are no Windows 98 drivers for this model -- it's not supported.
Posted on Jul 21, 2008
Win 98 in dos mode i get this message " no cd rom or msdex.exe is not loaded " when trying to acces game disk in cd rom
1) Does it say MSDEX.EXE or MSCDEX.EXE?
2) Have you ever used that CD successfully on that computer before? (DVD's don't work well in MS-DOS).
3) Verify its trying to run from the correct drive. D:, E:, etc...
That aside, I'd recommend a glance at the following support page. It sounds like your driver isn't supported or your game is referring to a specific drive that doesn't exist.
MSCDEX Help
(make a back-up copy your autoexec.bat, and rename it autoexec.bat.orig just in case)
Get an older compatible driver for your CD-Rom that is windows 98 compatible, so something around the year 2000 is probably ideal.
Uninstall your current driver and reboot. Scan for Hardware changes and install the new drivers for your CD-ROM. Then check your config.sys and verify the driver. If its not correct, open the autoexec.bat in an editor. in the portion of the autoexec.bat that has MSCDEX..exe program you'll put in the following. (replace DRIVERNAME with the driver name, typically MSCD001)
LH C:\WINDOWS\COMMAND\MSCDEX.EXE /D:DRIVERNAME
Save, reboot. Let me know how it goes!
Feb 08, 2013 | Computers & Internet
Hasbro MasterMind does not install on Windows XP or Windows 7 ! Do they have a newer version available ? I loved the game but it only played on Windows 98 ..... Anyone have any ideas ? Thanks...
Have you tried running the installer in compatibility mode? Right click on the installer (usually setup.exe or install.exe, and if you have it on a CD, you need to open the CD in My Computer as a folder by right clicking and choosing open), go to Properties -> Compatibility -> Check the 'Run this program in compatibility mode for:' check box, and select 'Windows 98/Windows' ME from the drop-down menu. Apply the changes or click 'OK', and try to run the .exe -file. If the game successfully installs, and you can't still launch it, do the same to the game's launch .exe -file.
Mar 22, 2011 | Hasbro Interactive MasterMind for Windows
"Go to this web site and down load the Win98
The file is still available fron the site mentioned ie. "setup.exe", size 41.9MB. If you are using IE to download, does "Informatiom Bar" pop-up? Then you click "download file". If not you should update your IE to version 6.
Hope it helps.
Nov 19, 2010 | Microsoft Windows 98 for PC
Error installing windows xp
hi! there,set up exe. that was when your setting up win 98 you have to install that came from floppy disk before you can install win 98.there is an os win 98 in your system you have to delete that previous os before installing another win xp.restart ur computer. press F2 to open your bios set-up . then select bios set-up priority your cd-room drive second,your hard drive. last, quit and save set-up. and then your computer will restart. insert your cd windows xp then reinstall your window xp. delete the previous os then follow the set up on your window xp until you install your new window xp.
Apr 01, 2009 | Compaq Presario S4020WM PC Desktop
Age of Sail Privaterr's Bounty will not play
You need to run it under windows 98 compatibility mode:
To do this locate the file "privateer.exe". By default, this file is located in Program Files/Global Star/Privateers Bounty - Age of Sail 2.
- Right click on the privateer.exe and select Properties.
- Click the Compatibility tab.
- Check the Compatibility Mode box by clicking in it.
- Use the drop down menu to select Windows 98/ME.
- Click Apply, and then click OK to close the window.
Hope this helps.
Graham.
Jan 08, 2009 | Global Star Software Age Of Sail 2:...
I`m unable to install windows 98 in seagate 80 gb ide barracuda hdd
For W98, if you create the bootdisk from within windows, you will need to go here to download the newest version of FDISK.EXE then copy it to the bootdisk, allowing it to overwrite the older version. This way you will have support for larger harddrives.
FDISK LIMITATION WITH 64GB DRIVES:
Why does FDISK not recognize my disk (or RAID array) which is larger than 64GB?
There is a bug in Microsoft's FDISK under Windows 95B, 98 and 98SE that can be corrected by downloading a newer version. See Knowledge Base Article Q263044 for more information.
http://support.microsoft.com/default.aspx?scid=kb;EN-US;q263044
When you use Fdisk.exe to partition a hard disk that is larger than 64 GB (64 gigabytes, or 68,719,476,736 bytes) in size, Fdisk does not report the correct size of the hard disk.
The size that Fdisk reports is the full size of the hard disk minus 64 GB. For example, if the physical drive is 70.3 GB (75,484,122,112 bytes) in size, Fdisk reports the drive as being 6.3 GB (6,764,579,840 bytes) in size.
NOTE: This hotfix is not designed for 48-bit logical block addressing (LBA) hard disks, and it is not supported on hard disks larger than 137 GB. However, even if the drive is physically larger than 137 GB, if you create partitions smaller than 137 GB, this FDISK.EXE version will work correctly. (THE FORMAT COMMAND WILL SHOW THE DRIVE AMOUNT IN DOS TO BE OFF THE MARK, BUT WILL BE CORRECT WHEN YOU GET INTO WINDOWS ITSELF)
Direct English Version download:
http://download.microsoft.com/download/Win98/Update/8266R/W98/EN-US/263044USA8.EXE
This package installs the updated Fdisk.exe to the Windows\Command and Windows\Options\Cabs folders, on a computer running Windows 98 or Windows 98 Second Edition. If you are starting a computer from a Windows 98 Startup Disk in order to partition and format the hard disk, you should copy the updated Fdisk.exe from the Windows\Command folder to the Startup Disk, replacing the original Windows 98 or Windows 98 Second Edition version of Fdisk.exe on the Startup Disk.
Dec 25, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Installing jetflash 2 windowsme
Download and install the following files and try again. The should also work with Windows ME as it is just a dressed up version of Windows 98.
For Windows 95, 98 and NT VBRun60.exe - VBRun60.exe installs Visual Basic 6.0 run-time files.
VBRun60sp5.exe - VBRun60sp5.exe installs Visual Basic 6.0 sp5 run-time files
For Windows 98 only DCOM98.exe - Extends the support for Distributed Component Object Model (DCOM) for Microsoft Windows 98.
Apr 10, 2008 | Computers & Internet
Canon pixma mp210
Canon downloads available
Please follow the steps below in order to install the printer driver for your PIXMA MP210.
First, please make sure that the printer is not connected to the computer.
1. Go to http://software.canon-europe.com/software/0027235.asp?model
2. Click on mp210svst100ea24.exe
3. Check "I accept" then click on Download software
4. Click again on the file m6A02mux.exe and save it to your Desktop.
5. After the download is complete, you will notice on the desktop a downloaded file: mp210svst100ea24.exe . Run mp210svst100ea24.exe and the setup will start automatically.
6. Follow the instructions from the screen in order to install the printer. When you will be prompted, please connect the printer to the USB port on the back of your computer.
7. After installing the driver, follow the same steps in order to download and install the MP Navigator as well: http://software.canon-europe.com/software/0027385_0010485.asp?model , mpnexwin105ea23-2.exe .
Feb 11, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
System Code Error 87
Sounds like the application you are running may not be compatible with Windows 98. Probably can't do much as Windows 98 is so old.
Although it may be a missing file, DLL, or driver on your Windows 98 system, hard to tell.
Jan 11, 2008 | Microsoft Windows 98 for PC
54 people viewed this question
old marine
old marine
