Question about Jenn-Air JCD2389G Side by Side Refrigerator
Freezer side leaking!
Our freezer is leaking and there's a new puddle every hour. any suggestions on how to fix this would be super helpful!
  • wilharem Sep 08, 2008
    water is leaking underneath on the floor
  • 134 Answers
When you say it's leaking, I guess the temperature is good and if there is a defrost cycle, it appears to be working correctly? Then it's possible there is a drain tube that's meant to allow the defrosted water is run away and that it's blocked. Blocked drain tubes quite often cause water to puddle inside a fridge. You might be able to clean the tube with some kind of chemical cleaner, like White King? or some other kitchen liquid cleaner. Or some people find the ends of the drain tubes and push a length of fine wire up or down the tube. It gets blocked with mold and food particles occasionally. The tube will run from your fridge compartment to a drip tray, usually sitting on top of the fridge compressor.
Here is a quote from:
the dr
"I use a little air pressure to clear drain lines, than pour a diluted solution of water and a little bleach down the hole water should drain fast and not pool."
Note: Beware of sharp edges and damaged electrical connections. There are a number of dangerous areas to work on, inside & under appliances. Good Luck. Dave.
Posted on Jul 26, 2008
LG Refrigerator model # LRFC25750TT Twice, I've found a small puddle of water in the front right side of the refrigerator (as you face it). This was found approximately 2 weeks apart. I've check the...
To identify whether your unit is leaking, please check the bellow link to troubleshoot your problem:-
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting
Mar 01, 2011 | LG Refrigerators
MZD2766 GE - A puddle of ice forms at the bottom of the freezer
Sounds like the defrost drain is cloged. There is a hole at the bottom of the freezer behind the back wall. if this is cloged then the water that is suppost to drain there will overflow and freez.
Jul 04, 2010 | Maytag MZD2766GES Side by Side...
Water is leaking out from the bottom of the freezer
Below the freezer coil is a drain trough. Sounds like it is frozen. Use a hair drier to melt it and poor baking soda with warm water down it.
Jun 02, 2010 | GE Profile PSS26NGS Side by Side...
Our side by side is leaking water in a puddle on the left front corner (water dispener side) off and on. 9 year old refrigerator. Refrig/Freezer and ice/water working well.
I'm going to give you a lot of information on one page please choose thye part that most defines your situation and I will be here to assist you, Please rate me, Thanks, Sea Breeze
Click Link Below
Aug 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a puddle forming on the freezer side of the maytag msd2756gew side by side refrigerator. It seems i have a leak. what could be leaking and how do i fix it?
Your Ice Maker could be leaking or the defrost drain behind the back freezer wall could be blocked with ice or another source of blockage leading down to the pan below your refrigerator where the water is heated by the evaporator fan and replaced back into the air inside your home. You will need to unplug the power before going into the back of your freezer. Let me know if you would like help. Sea Breeze
Jun 26, 2009 | Maytag MSD2756G Side by Side Refrigerator
Hotpoint csx22bc 21.7 cu. ft. leaking water on freezer side
Look for obstruction at the drain tray for the freezer. Common to have plastic wrap sucked into that area.Or gunk in the drain line. Blow through line to insure the gunk is not an issue.
Mar 01, 2009 | Whirlpool 21.7 cu. ft. Side-by-Side...
Leaking water from freezer
take back panel off inside freezer. you will see a drain tray at the bottom with a drain hole in the middle. this is blocked with ice. melt off ice with a hairdryer and follow up with hot water till it flows away freely.
also check the drain tray heater is ok
Oct 13, 2008 | Refrigerators
Frigidaire FRS26ZSH freezer leaking
Plz provide me with a e mail adres so i can foward a users manual to you for a Frigidaire FRS26ZSH.
Aug 31, 2008 | Frigidaire FRS26R4A Side by Side...
could mean ice build-up on evaporator - buzzing could be fan jammed asgainst ice. remove back panel of freezer to check. this would usually affect fridge as well however
Apr 10, 2007 | Frigidaire FRS23R4A Side by Side...
Jenn-Air JCD2389G Side by Side Refrigerator Logo
171 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
