Question about Canon CanoScan LiDE 70 Flatbed Scanner
CanoScan changes size when scanned
  • 3 Answers
What changes? you need to provide more information if you expect an answer. Resolution? What sizes are represented in the boxes? Selection Print size etc.
Posted on Jul 29, 2008
Problem with Canon Lide20/30. I want to multi scan photos. The multi scan in the simple mode is not working. The multi crop and size signs in advanced mode are not enabled. Tried uninstalling and...
Check the manual for that on this link http://safemanuals.com/user-guide-instructions-owner-manual/CANON/CANOSCAN%20LIDE%2020-_E
Hope it helps.
Mar 11, 2011 | Canon LIDE20 Flatbed Scanner
When I scan a letter size doc the output is only half or part of the original. Not all the page is scanned.
Here is what you should check:
1. Ensure that the original is flush against the front edge of the scanner platen (towards the scan, copy and e-mail buttons).
2. Ensure that "Paper size" is set to "Letter."
Regards,
MyEfact
Dec 20, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
When scanning in the pdf mode , i get a " get disk free space error "
Reduce the scan resolution before trying to scan in pdf mode or the saved file size will be far too large for your limited hard drive space.
Aug 17, 2010 | Canon CanoScan LiDE 70 Flatbed Scanner
CanoScan LiDE 20 started stretching image at the beginning of the scan, continuing just fine afterwards. Bottom part of the image (in my case a letter-size page) will not fit, about 1/4 of an inch would be...
Hi pallada,
This might be a case where we address the symptoms rather than the problem.
Instead of positioning the paper to be copied at the normal position, drop it down to the 2" mark. Then on the preview screen, adjust the area to be scanned down accordingly.
This should allow a full letter size scan with no loss, truncation or stretch.
Best regards,
Mike
Jul 18, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Couple of problems for canoscan 3000f :
It appears the scanner is not scanning in the vertical direction.(I am assuming it is able to scan the full width). Try unistall and reinstall of the friver. This can work. There are sensors in the scanner that indicate the 'end of scan area'. Check if any of them is blocked by shreds of paper or dust.
S. Mohan
Feb 24, 2009 | Canon CanoScan 3000F Flatbed Scanner
I want to increase size of small items to make them more legible
Open the file with MS Paint (Start>Programs/All Programs>Accessories>Paint), go to Tools, then Stretch/Skew, then enter the size of the new image compared to the old. (100% is no change) Then click OK and save the file.
Jan 11, 2009 | Canon CanoScan LiDE 25 Flatbed Scanner
Canoscan 20
I had the same problem..the way to get around this is to open the toolbox and click "Save" instead of "Scan" After you do this you just create a file name and save it into a folder..also make sure you change the "save as type" to JPEG
Dec 18, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Using PaperPort 11 to scan
If you will go through the Advanced Setup wizzard and it completes you will have access to the "Display Scanner dialog"
Jul 18, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Canon CanoScan LIDE 25
Use the PDF function of the CanoScan Toolbox. On the options screen for a pdf, click the drop down box next to “Save as Type:”. Select “PDF (Multiple Pages)”. This option causes CanoScan to stop after each page is scanned and ask if there is a next page or if you are finished.
May 04, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Scanning Different Sized Sheets
There should be a preview option that scans more quickly than actually scanning the page. Then after the preview shows, you can select the area that you want to actually scan and then you hit the Scan button. If you are using the Canon software, this should work for ya.
Nov 07, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
old marine
old marine
