Question about Philips 42PF7320A 42 in. Plasma HDTV
Four red flashes
Turn on TV , goes to 4 red flashes (pause) 4 red flashes continuing until you remove TV from outlet power. Can you help?
  • Anonymous Sep 15, 2008
    I have the same basic problem, although I can get the TV to power on after unplugging it (sometimes takes several tries...).
  • 52 Answers
If 4 blinks is consistent and even after unplugging tv still does not power on would recommend replacing small signal board as error is i2c communication failure which is specific to microprocessor located on small signal board
Posted on Aug 21, 2008
Ways to fix red lights blinking four times
Red Power LED
flashes once
every two
seconds.
OR
Red Power LED
flashes four
times, once
every second,
followed by a
two second
pause.
None Power failure
(power supply is
overloaded).
1. Check that the voltage selector,
located on the rear of the power
supply, is set to the appropriate
voltage. Proper voltage setting
depends on your region.
2. Open the hood and ensure the 4-wire
power supply cable is seated into the
connector on the system board.
3. Check if a device is causing the
problem by removing ALL attached
devices (such as hard, diskette, or
optical drives, and expansion cards).
Power on the system. If the system
enters the POST, then power off and
replace one device at a time and
repeat this procedure until failure
occurs. Replace the device that is
causing the failure. Continue adding
devices one at a time to ensure all
devices are functioning properly.
4. Replace the power supply.
5. Replace the system board.
Jun 14, 2014 | HP Compaq dc5000 Small Form Factor PC...
Four flashing red lights then one green - no picture. This hapoens when I try to turn it on, The screen stays black and has white horizontal line.
Solution
sp.gif sp.gif The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
Oct 24, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony bravia kdl55hx729 3d led tv turns on 3 seconds shows picture than four red flashes
the error light sequence that you are seeing is indicating a "backlight error". Most likely you have a bad inverter board -the board that powers up the back-lights behind the display panel. They might be available via ebay if you are a DIYer, or you need to call for sony service.
Good Luck!
Rich Lilja
Dec 07, 2013 | Sony Bravia KDL-55HX729 LED Internet TV...
My HP D530C does not power on. The power LED flashes 4 times. What is the fault? Pls let me know asap. Thanks.
HP xw6200 Workstation - Diagnostic LED Code: Four Flashes ISSUE: When the workstation is powered on, the front LED might flash red four times, once per second, followed by a two second pause. SOLUTION: The front LED flashing four times is a sign of a power failure. To fix this issue, complete the following steps:
  1. Open the access panel, and check to see if the four-wire power supply cable is properly connected to the system board.
  2. There may be a faulty device. Locate it by removing all devices and then reinstalling them one at a time until the workstation fails. Replace the device causing the failure. Continue adding devices to ensure all are functioning properly.
  3. Verify the power supply functionality, as follows:
    1. Disconnect AC power.
    2. Remove all internal power supply cables from the system board.
    3. Plug in AC power.
      • If the power supply fan spins, and the BIST LED illuminates, then the power supply is good. Replace the system board.
      • If the power supply fan does not spin, or the BIST LED does not illuminate, replace the power supply.
Dec 13, 2011 | HP Compaq d530c PC Desktop
When you turn of the TV the POWER indicator flashes green for several minutes. The TV never comes on. After the several minutes of the POWER indicator flashing green, it stops, I hear a click and the...
A continuous flashing red light with the word LAMP on it would definitely mean you're going to need to spend a few bucks on a new lamp....or for a few more, upgrade to a TV from this century that doesn't require lamp changes :)
May 11, 2011 | Panasonic PT-52LCX66 Projection Television
TV will not turn on. Red light flashes 4 times
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Mar 07, 2010 | Sony KDS-R60XBR2 Television
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony KDP-65S550 red light keeps blinking
The STANDBY light is flashing on the television and there is no picture or sound. Solution
Jun 28, 2008 | Sony Grand WEGA KDP-65WS550 65" Rear...
T.v goes on no screen just blinking stand by light red
Apr 09, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Red light flashes four times
4 red light flashes normally means there is a problem with the fan. Time to make a service call.
Dec 19, 2007 | Sony KDSR50XBR1 50" Projection HDTV
Philips 42PF7320A 42 in. Plasma HDTV Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
