Question about Maytag MZD2766GES Side by Side Refrigerator
MZD2766GES Maytag defrost problem
Need help locating the adaptive defroster board or the defrost timer. Where is it found in the refrigerator?
Thank-you
    Champion:
  • 210 Answers
In fresh food part on top right, remove the housing assy.
Posted on Aug 07, 2008
Maytag refrigerator moldel msd2756dew coils are freezing over
There are three magor parts that control the defrost on your model MSD2756DEW Refrigerator. The=> MSD2756DEW Controls are inside the fresh food compartment and behind the controls on the top shelf. In that photo is position 13 That is your ADC or adaptive defrost control part number=> 61005988
This is most likely the reason for not defrosting and causing the evaporator to ice over. The next part is the=> 61006199 Defrost Heater with Defrost Thermostat
sea_breeze_142.jpg Here is a PDF of a Maytag MZD2766GES and it has the same parts as yours so click here=> Maytag MZD2766GES Just use it for illistration or parts. Click here=> Defrost Heater Assembly to see that part and at bottom of page there is a short movie of how to test the defrost heater with an OHM meter. This is not hard to do if you want and I will be here if you need to ask other questions. If you have questions please let me know, Thank You, Sea Breeze
Apr 18, 2011 | Maytag MZD2766GES Side by Side...
Where is the timer switch?
Good day,
It doesn't use a standard timer but rather an adaptive defrost control which is really an electronic version of the old mechanical style.
It's located in the top of the fresh food compartment behind the main controls.
It looks like this.
May 17, 2010 | Maytag MZD2766GES Side by Side...
Have a Maytag MZD2766GES Side by Side Refrigerator, somehow it just stopped working. The freezer part is just a little cold but the other side is not cool at all. What can it be?
check the freezer compartment, remove the shelves remove the cover in the back if the condensing coil is frozen solid your adaptive defrost board or defrost coil is bad. a temporary fix is turn off refrigerator, defrost coil ( I used a space heater). turn refrigerator off . you will need to do this every third day until adaptive defrost board is replaced. to check defrost coil check with ohm meter It should have resistance. this website should give you the gory details http://www.appliance411.com/faq/howdefrostworks.shtml
Dec 15, 2009 | Maytag MZD2766GES Side by Side...
Frig side not working on Maytag MZD2766GEW
freezer not defrosting. probably adaptive defrost board in fridge.
take panel off freezer (inside, back panel). if all frozen, can defrost with blow dryer. best to remove fridge control panel (inside, top of fidge). access adaptive defrost board, jump test to f1 (i think) next to test. this should initialize defrost mode. buy new board.
May 23, 2009 | Maytag MZD2766GES Side by Side...
Not cold
Inside the fresh food compartment there is an adaptive defrost control. If it is bad it will cause the evaporator coils to freeze and reduce cold air circulation throughout your refrigerator. You can unplug your refrigerator and remove the control panel as to view the board. Sometimes you will see burn marks but not always. You also can while unplugged remove the back panel in the freezer compartment to see if ice is present and if so you can defrost the ice and examine the defrost heater to make sure that it is ok. The part number for your adaptive defrost assembly is 61005988
I am using the model number above your post so please correct me if wrong. Model number MZD2766GES
Go to link below, they offer free help and assistance.
Enter model number in the model and parts search feature. Thanks, Sea Breeze
When you get to the model page on left click picture #2 controls
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Maytag MZD2766GES Side by Side...
I need to know where the adaptive control defrost board is located in the fridge
In the top right rear corner of the control panel.
What is your problem?
BTW your fridge is on recall from Maytag.
Apr 13, 2009 | Maytag MZD2766GES Side by Side...
Mzd2766ges
its located in the upper right corner of freshfood side. sometimes its hard to get to. remove light shield, then heat shield, then the auto damper housing assy. and then 2 scews holding the defrost board,remove the 4/6 wire plug to board carefully. also unplug refridgerator first. good luck.
Aug 27, 2008 | Maytag MZD2766GES Side by Side...
Defrost timer board for mzd2766geq
Defrost control board is in the top of the refrigerator behind the two levers that control the temperature. You have to take off the plastic cover. There are two screws and then you slide to cover to the side to remove. The board is in a white plastic housing.
Aug 15, 2008 | Maytag MZD2766GES Side by Side...
Maytag MZD2766GES Side by Side Refrigerator Logo
285 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
