There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
There are many reasons why a dehumidifier willnot work or collect water. Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Based upon my experience with the same problem on my Kenmore 54701 last summer: The condensate water collects in a plastic pan below the coils. This pan has a single drain hole where the water flows down into the bucket. When I suddenly found water puddling on the floor instead of in the bucket, I opened up the unit, and I found that the collection pan's drain hole had become blocked by "bioslime". I cleaned out the goo from the drain hole, and the problem was solved.
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
These are somewhat related to cooling systems so the system may need a coolant recharge like any AC.
Check your user guide to see if there is any mention of a need for recharging.
Either there is a hole/leak in the tray, or the drain line is clogged. You are giong to have to access the tray to determine this: standing water is plugged line and no water is busted pan. This will determine your avenue of approach.....
Mine leaks. Had leaked at other times but i took the vacuum cleaner
to the front drain spout, that leaks into the removable basin. That
worked in the past, but i't's not working now . The water is
overflowing at the back of the catch tray and leaking out through the
bottom underneath. The holes are clear, so it shouldn't be doing this.
I am stumped.
