Question about Casio Boss Business Organizer
Casio BOSS 5300
My BOSS 5300 organizer displays DATA ERROR CONSULT OWNERS MANUAL. I do not have a manual for this organizer. Any suggestions to help would be appreciated.
I would suggest doing a "Reset". You will loose all your data, but at least you will be able to use it. You do a Reset by removing the bottom case, turning on the BOSS, them pressing the Reset button located inside.
Posted on Sep 24, 2008
It says consult owners manual fo data error
For Digital Diary Owners Manuals:
http://support.casio.com/en/manual/manuallist.php?cid=013
Oct 01, 2013 | Casio B.O.S.S. SF-5300b: Business...
Cannot retrieve data
can you please post the model number?
Jan 12, 2008 | Casio Boss Business Organizer
Trying to obtain a manual for the SF-5300.
On the back battery cover there is a reset button,just push it w/a toothpick or pencil point. It will reset you B.O.S.S. so you can re-enter info. I've had mine since '00 e-me @ icabod39@att.net if I can help or confuse you more. Good luck! P.S. I'm not assotiated with casio.
Jul 13, 2009 | Casio Boss Business Organizer
Casio SF 4600
You have to press the reset button on the underside.
Note, You will lose all data!
Jun 23, 2009 | Casio Boss Business Organizer
Casio boss 5300 questions
If you can see something when you turn it at an angle I would suggest turning the contrast dial to see if visibility improves. As far as a copy of the manual, I found one here:
http://servicemanuals.electronica.ro/manuals/casio/SF-5100_SF-5300.pdf
Good luck.
Aug 24, 2008 | Casio Boss Business Organizer
Casio BOSS SF-5300
Once the DATA ERROR DISPLAY appears,You will not be able to INPUT or EDIT DATA, though you will be able to recall Data after pressing CLEAR to clear the error message.**YOU WILL
WANT TO SAVE ALL YOUR DATA OR WRITE EVERYTHING DOWN AT THIS POINT, BECAUSE THE ONLY WAY TO GET
THIS DEVICE BACK TO NORMAL OPERATION IS TO PRES RESET IN THE BACK -IF YOU PRESS RESET YOU WILL LOSE ALL INFORMATION PERMANENTLY.
In order to return the memory to normal (allowing further input and editing of data), you must perform the RESET OPERATION to clear the memory of all data-Make sure you have backed up or taken a hardcopy of this information before Resetting or it will be gone and there is nothing you can do to get it back.Once you have RESET you can re-input the data you have written down.
WHAT CAUSES THE ERROR MESSAGE?Interruption of battery power.Severe electrostatic charge,impact,change in temperature
or humidity.Hardware Problem.
Recommendations:Replace batteries every 2 years, regardless of use.Use only CR2032 Lithium batteries.Replace all batteries-Never mix old ones with new ones!
Caution: All data stored is lost if you remove more than 1 battery at a time. The following Info is per the instruction manual-WHICH ALSO SAYS :Be sure you keep a separate copy of all important data that you store in the SF-5100/SF-5300.Hope this helps.
May 28, 2008 | Casio Boss Business Organizer
305 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
